Results 1 to 10 of 10
Thread: MY 7" display not showing screen
    Nov 2013
    I have a 7" AMS Impex screen. Actually when i connect it, it gets the power but no screen appears. I have been told it should have a blue screen when power is on. But no screen comes. Just a green light appears. Here are some pics to clarify
Size:  170.9 KBName:  2013-11-20-366.jpg
Size:  137.0 KBName:  2013-11-20-367.jpg
Size:  153.2 KBName:  2013-11-20-364.jpg
    See the green lights on panel when connected to smps
    Raw Wave SNOtwistR's Avatar
    Nov 2009
    Keswick,On Canada
    Welcome to the forum! Have you set to vga output in the bios, not sure what mainboard we are working with. does the monitor have multiple inputs? hdmi/digital/vga/component/rca type please fill in the details SNO
    Maximum Bitrate camo.b's Avatar
    Nov 2011
    The only thing mine shows is a black screen and a no signal message...on some you can turn off the blue screen...The blue screen is super bright at night and I can't imagine anyone not disabling it
    Sent from my SM-N9005 using Tapatalk
    Nov 2013
    Quote Originally Posted by SNOtwistR View Post
    Thnx. My MOBO is a gigabyte e350n. Honestly i bought a used one. The seller said that a blue screen should come at the start when it recieves power then when it has some input it would work. I also tested it with my pc. but still its not working only power light is on. The screen has VGA & HDMi input.
    Nov 2011
    Okay try switching the inputs manually with the buttons on the front
    Nov 2013
    Quote Originally Posted by camo.b View Post
    If u are telling to press the power button when green light is on then i have already done it. Also tried to turn on with remote.
    Is there any thing else that i can check personally in lcd or control board or front panel.
    Nov 2013
    i think there is some mistake in control board. Can u guyz suggest me what cani chk in control board & what r the tools required. i think so becozz no blue light is appearing front panel which should come
    Feb 2012
    Sounds like the cold cathode could be shot. Thats the thing that lights up the screen. to test go into a very dark room and turn it on. Look closely, do you see anything?
    Nov 2013
    Quote Originally Posted by psi3000 View Post
    Can u throw some more lights on cold cathode? What will i observe in a dark room I don't understand? How will i repair it?I think blue light is no glowing in panel so it might be the logic board
    Can nyone suggest how can i chk the logic board using multimeter or ny other tool which could help me.
    Feb 2012
    OK RULES,
    I think i see from the last picture whats going on. Look at the blue circuit board. It looks like a liquid was spilled on it. I see lots of residue consistent with a spill of some kind. Get some rubbing alcohol , the more pure the better. I like to use the %90 i think it is. take some Q-tips and dip them in the alcohol and clean that mess up. Make sure there is no oxidation between any of the connections. Also check the green board as well, from both sides as well. Let me know how you make out.
  1. FS: 12.1" 800nit display / 12.1" NEW Touch screen Kit
    By therussman2002 in forum Classified Archive
    Last Post: 07-26-2005, 09:44 PM
  2. showing mediacar ONLY on the second display
    By chiefsalami in forum LCD/Display
    Last Post: 08-28-2004, 10:24 PM
  3. Native res on "8" VGA Touch Screen TFT LCD Display"
    By MrSpace in forum LCD/Display
    Last Post: 07-17-2004, 12:34 PM
  4. F/S, 10.4" Touch screen Display (Ebay)
    By evank in forum Classified Archive
    Last Post: 07-29-2001, 01:17 AM
  5. F/S, 10.4" Touch screen Display
    By evank in forum LCD/Display
    Last Post: 07-29-2001, 01:16 AM
