Results 1 to 4 of 4
Thread: 8.75" x 5.3" - Best display with these max dimensions?
    Dec 2013
    Question 8.75" x 5.3" - Best display with these max dimensions?
    For an upcoming project, I play to spend a maximum of $300, preferring about $200 if possible.
    And my max dimensions are 8.75" x 5.3".
    It will be a custom fab install where I tear apart my SUV's center dash for it.
    What is a good touch screen in that price range?
    It will be for a PC running Android.
    I just need it to have:
    • HDMI input
    • auto-power on
    • RCA Video input for rear camera
    • auto brightness, or the ability to control brightness by external input.
    This is the best thing I could come up with on my own, but I'm new to this and not totally sure what to look for:
    • High Brightness Lilliput 869GL-80NP/C/T-HB 8" Touch Screen LCD Monitor DVI HDMI
    http://store.mp3car.com/High_Brightn..._p/mon-137.htm
    FLAC rray's Avatar
    Apr 2012
    SF Bay Area
    I'm guessing that panel is about 7.5" x 4.4" once removed from the housing. I found they usually add 6mm per side X and 5mm per side Y to the active screen dimensions. (viewable area)
    Dec 2013
    Yeah, the max dimensions include any sort of open bezel or "regular bezel".
    After tearing up dash, I get:
    W = 8.75" / 222.3mm
    H = 5.3 / 135mm
    I used a screen size calculator for a 16:9 type and got these numbers:
    10" Diagonal screen is 8.72 x 4.9
    9" Diagonal screen is 7.84 x 4.41
    So I'm thinking a 10" screen is out. But a 9" open bezel might fit.
    FLAC rray's Avatar
    Apr 2012
    SF Bay Area
    One other thing to remember is the brightness decreases with larger panel sizes. Here are the sizes (25.4mm per inch) I found when I was looking for an open frame screen in the 16:9-10 aspect:
    160.8 x 106.8 x 4.2 600:1 Contrast 400 Luminance 7" 1280 x 800
    192.8 x 116.9 x 6.4 600:1 Contrast 400 Luminance 8" 1024 x 600 ZJ080NA-08A 1024*600 CHIMEI INNOLUX May 2012
    192.8 x 116.9 x 6.4 500:1 Contrast 450 Luminance 8" 1024 x 600 HSD080IDW1-C 800*480 HannStar 2009 Dec 2009
    192.8 x 116.9 x 6.4 500:1 Contrast 450 Luminance 8" 1024 x 600 AT080TN64 800480 Innolux Mar 2010
    213.4 x 129.6 x 5.45 500:1 Contrast 180 Luminance 8.9" 1024 x 600
    211.1 x 126.5 x 5.9 400:1 Contrast 200 Luminance 9" 800 x 600
    210.6 x 166.6 x 5.8 400 Luminance 9.7" 1024 x 768 (a 4:3 aspect screen)
  1. LCD Dimensions
    By reece146 in forum LCD/Display
    Last Post: 10-24-2007, 04:08 PM
  2. Some help with dimensions..
    By stealinfool in forum LCD/Display
    Last Post: 02-22-2007, 06:46 PM
  3. Dimensions
    By spade44 in forum Fabrication
    Last Post: 07-21-2006, 11:05 AM
  4. Dimensions?
    By sup2jzgte in forum General Hardware Discussion
    Last Post: 10-14-2005, 07:58 PM
  5. Dimensions
    By sux89 in forum MacCar
    Last Post: 05-30-2005, 11:31 AM
