Results 1 to 10 of 17
Thread: SHARP LQ123K1LG03 12.3 inch 1280*480 LCD Screen Display Control board
    Feb 2012
    ok I see these 12.3 inch sharps on ebay but with no control board. Does anyone know what control board is comparable with either a vga or HDMI hookup? Can I use the one from the 7 inch Samsung that Derek sells on ebay? I really need this display for my setup but without a control board theres no point to buy it.
    Raw Wave SNOtwistR's Avatar
    Nov 2009
    Keswick,On Canada
    That 480 is very low, also the specs on that monitor are not very good "Brightness : 150 cd/m2 (Typ.) Contrast Ratio : 20:1 (Typ.) Display Color : Monochrome Viewing Angle : 40/40/40/40 (Typ.)(CR≥2) Frequency : 75Hz" I think I would look for something else unless you are looking for monochrome and not colour SNO
    Looks like I am getting conflicting specs on this here is from another site
    Model LQ123K1LG03
    Manufacturer Sharp
    Diagonal Size 12.3
    Display Area (W x H in mm) 292 x 104
    Resolution 1280x480
    Brightness 330 cd/m▓
    Contrast Ratio 400
    Refresh rate (Hz) 60
    Response time (ms) Gary to Gray 10 Rising 10 Falling
    Viewing Angle - Vertical 110
    Viewing Angle - Horizontal 130
    Color Depth 8 bit
    Panel Interface LVDS
    Panel Voltage vDC 3.3
    Backlight Type CCFT
    Operation Temperature ░C - ░C
    Outline Dimension (W x H x D in mm) 321 x 130 x 26
    Application Automotive
    May 2010
    Herákleion, Iraklion, Greece, Greece
    i have also seen that panel... it might indeed , not be so good, but its the only thing available on Ebay with that dimensions (which are SWEEET for a digital speedometer, where HD is anyway not needed)
    if you search for something like 12" sun visors, you will get some sun visors, which use exactly that panel.... but they are RCA Input....
    let us know if you find anything!!!
    Feb 2012
    Looks like this might work:
    M.NT68676.2A(HDMI+DVI+VGA+Audio) LCD/LED Screen Controller Board Diy Monitor Kit
    I contacted the distributor to see if it will work.
    May 2010
    nice!! please let me know of the outcome !!
    Maximum Bitrate camo.b's Avatar
    Nov 2011
    Chinatobby on ebay...kevin there can get anything to work.
    Newbie Lucifer's Avatar
    Aug 2004
    Belgium
    Any news on that controller? Just ordered one of these screens and also looking for a controller.
    Morex 3688 (Via MII10000 - 512Mb - 2,5HD 30Gb DVD+RW)
    CarTFT Motorized 7" In-dash Touchscreen
    CNX 1260
    Current Status: Skinning !
    Nov 2011
    Chinatobby on ebay has controllers probably suitable for your screen.ill grab a link
    Feb 2012
    Quote Originally Posted by camo.b View Post
    I cant find Chinatobby on ebay..... I ordered the controller board last month from some place on ebay but it will take another month at least to get it. Maybe I can cancel this order and go with Chinatobby if you can supply a link or double check the name....
    Oct 2010
    Greece
    Quote Originally Posted by psi3000 View Post
    i think he is the best seller i ever met on ebay
    Vw Sharan 2007 1.9tdi || Exide 100Ah
    Fuzzy 945gme + core duo T2400 + 2gb ddr 667 + pci nvidia 5500 256mb + kingston v300 60gb + hdd 2.5" 100gb 5400 + Sure Gps module
    Primary monitor 8" 800x600 || Secondary monitor 15.4" 1280x800
    Powered by M2 atx
  1. Tiny XP won't display on 8 inch screen
    By hotrod6657 in forum LCD/Display
    Last Post: 06-19-2008, 01:08 AM
  2. Replies: 8
    Last Post: 01-21-2008, 01:54 AM
  3. FS Sharp 5.7 inch B&W Touchscreen LCD
    By Kubla Khan in forum Classified Archive
    Last Post: 11-27-2004, 01:43 PM
  4. 8 inch Sharp - why not popular?
    By Danneman in forum LCD/Display
    Last Post: 04-13-2004, 05:00 PM
  5. Sharp 8.4" TFT Touch Screen With Driver Board
    By PaulzY in forum LCD/Display
    Last Post: 10-08-2001, 10:28 AM
