Results 1 to 4 of 4
Thread: Lilliput FA1011-NP/C/T reverse wire
    Dec 2005
    Perth, Australia
    Hi all,
    I'm trying to find info on the Lilliput FA1011-NP/C/T reverse sensing wire. Is there a manual or diagram as to where on the circuit board this wire should be attached and does it just want a 12V source ie plugged into positive reverse light wire?
    Raw Wave SNOtwistR's Avatar
    Nov 2009
    Keswick,On Canada
    Yes that's how you do it. You can also have your camera turn on that way as well. Hope this helps SNO
    Dec 2005
    Perth, Australia
    Ok thanks, but I just need to find the diagram where you put the wire, unless it is done at the factory?
    Dec 2005
    Perth, Australia
    Ok I've got access to the reverse light wire that I can hook up to the monitor, but where does the 12V line go to? Here is a picture of the inside of the screen:
  1. Lilliput reverse signal wire doing something weird!
    By jeunefred in forum LCD/Display
    Last Post: 06-23-2014, 11:02 AM
  2. Replies: 8
    Last Post: 09-02-2013, 01:21 PM
  3. Lilliput FA1011 Intermittantly Responding
    By 2MuchRiceMakesM in forum LCD/Display
    Last Post: 02-11-2013, 04:58 PM
  4. Lilliput FA1011-NP/C/T touchscreen 90 degrees off?
    By toomuchdogfur in forum LCD/Display
    Last Post: 08-17-2011, 05:12 AM
  5. HDMI and reverse wire Lilliput
    By jdmagoo1 in forum LCD/Display
    Last Post: 12-16-2010, 08:13 PM
