Results 1 to 7 of 7
Thread: 2 LCDs one controls the other?!
    Feb 2012
    I have a micro atx using two "Transflective" LCD panel with res touch+controler " (the ones that derrek sells on ebay). I cant for the life of me figure this out: I only have the one touch screen hooked up to a usb port. However, it controls the other touch screen. Is it in the software that I need to set this up? anyone else experience this? I googled this with 0 results.
    thanks
    Raw Wave SNOtwistR's Avatar
    Nov 2009
    Keswick,On Canada
    It sounds like you have the screens mirrored and not extended. change in your graphics card settings app or in windows display settings and extend your display. Just a thought SNO
    Feb 2012
    I dont think they are mirrored. As one is running the gauges and the other your frontend SNO. I will close both and see when i get home today.
    Variable Bitrate eugenweij's Avatar
    Aug 2010
    Rozenburg, Netherlands
    There should be an option in the setitings of your touchscreen driver where you can select on what screen your touchpanel should be working.
    What software/driver came with your touchpanel?
    View my worklog here
    Mod - Driveline forum
    ClockWorK's Avatar
    Oct 2003
    Michigan
    It might be as simple as swapping the order of the screens in Display properties.
    Or it could be that the touch-screen driver assumes that it's the primary screen.
    FLAC rray's Avatar
    Apr 2012
    SF Bay Area
    I have one of Derrick's screens and the touchscreen acts in effect like a Mouse. I would think you need to set your video driver to span or extended screen mode, but to test this, plug in a USB mouse and see if it is able to travel over both screens.
  1. Q. About XGA TFT LCDs
    By Boostz21 in forum LCD/Display
    Last Post: 10-03-2005, 09:47 AM
  2. where to buy LCDs
    By adidas445 in forum LCD/Display
    Last Post: 04-14-2005, 06:20 PM
  3. FS LCDs in the UK
    By EddyP in forum Classified Archive
    Last Post: 08-09-2002, 03:59 PM
  4. LCDs Again!
    By Arby in forum Classified Archive
    Last Post: 12-25-2001, 02:45 AM
  5. What to do with 2 LCDs
    By medcalf in forum General Hardware Discussion
    Last Post: 03-30-2001, 11:34 AM
