Results 1 to 10 of 12
Thread: Flush Screen Install Finally Done (not perfect but the best I could do)
    Jul 2002
    Alabama
    Jan 2003
    Ruston, LA
    Looks decent, don't beat yourself up
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
    Feb 2002
    Ontario, Canada
    I agree with Frodobaggins and the only way i could see it looking any better is if you smoothed it into the dash piece with no seems with fiberglass and then get some fake wood mac tack stuff and cover the dash piece and cut out only the actual screen area.
    GTI - Palm IIIe controlled with Radio faceplate hack for keyboard control of WinAmp w/ Vocal Genre playlist loading.
    VW Bus - 10.4" vga lcd. Loaded with same software as above.
    Raw Wave Defiler's Avatar
    Jan 2002
    Temple Terrace, Fl.
    Oh, MAN!!!! That thing looks friggin' horrible!!!!
    JK.
    It looks pretty good. I would love to have a flush mount that looks that good in my car...
    Aura MR62 (F and R)
    My Current MP3s
    IamDefiler.com
    FLAC Skraggy_uk's Avatar
    May 2002
    Warrington UK
    It's not bad. better than mine which I shall be posting an update of it once I get the screen inside, and my hand heals.
    Why does filler look so much smoother till you get the paint on. Then it turns into a roller coaster with moon craters thrown in.
    4x4 in a turbo stylee.
    Maximum Bitrate jzgt's Avatar
    Mar 2002
    Quote Originally Posted by Skraggy_uk
    That's true - it does...When you're working with fillers or fiberglass, it's important to lay down a guide coat of a contrasting color (usually black) and then lightly sand the surface. Where you see the paint after sanding is a low spot.
    - Jeff
    May 2002
    Warrington UK
    Yeah, I know. Did a couple of times like that, of sanding, spraying filling, sanding, spraying, got bored and thought F&^k it, good enough. Well for me it is, but it isn't really. If it way my body panel visible from the outside, and I had paid someone to do it, I would freak.
    As it is, it is a 20 year old piece of under dash (that had it's own digs, dints and chips anyway) lower console, that is shadowed by the dash most of the time, and barely visible anytime thanks to light factory bronze tinted windows.
    It won't look perfect, but it will look OK (except to me, who knows it isn't "Quite" there.
    Mar 2002
    Yeah - I did a shifter boot trim piece a long time ago (my first fiberglassing experience) and it looked great...until I painted it - then the panel looked like it was waving at me . 2 days later, it looked halfway decent. I've finally gotten a little better at it..but it is, like you say, back and forth with spraying and sanding.
    - Jeff
    May 2002
    Warrington UK
    I guess I get impatient. Took me two years to build version 1 car PC(about 6 weeks actual building and fitting), then after using it for about 3 weeks, I bought all the bigs for version 2 including a 10.4" TFT VGA that actaully wouldn't fit in my car without some work to it.
    Now I'm rushing. Must slow down.
    Maximum Bitrate gizmomkr's Avatar
    Dec 2000
    Smyrna, Ga, USA
    I know the feeling - the LCD looks good.
    I hate having the project span days or weeks, or more.
    Once I start something, I just want to keep at it till its done.
    This whole mp3car seems to have adverse effects on sleeping.....
    Gizmo-
    Techonlogy on Wheels
    http://www.hjnetworks.com/car
