You might be able to hook it in to the feed coming from the indicator stalk on the steering column, as that will be a constant feed before it goes into the relay/flasher unit.
Garry
I Know A Lot Of Guys Have Put A Rearview Camer In Their Car So I Want Ot Take Mine To The Next Level. I Want To Install 2 Rearview Cameras (one Color - For Daytime Viewing , And One Infrared For Nighttime Veiwing) And 2 More Infrared Inside My Side Mirrors For Night Time Use Becase My Tinted Windows Make It Hard To See Outside At Night- And For The Cool Factor.
I Need Help Building A Circuit To Turn On The Cameras In The Side Mirrors On When I Use Either Turn Signals . I Figured That I Can Connect The Rear View Cameras To My Backup Lights So They Only Come On When The Vehicle Is In Reverse. Currently I Have A Lcd Display In My Visor And Another Lcd Display On My Dashboard
I Need Some Ideas Bucause I Have Been Racking My Brains But No Bright Ideas Pop Up.
I Definitely Cannot Connect The Side Cameras To My Turn Signals Cuz Everyone Knows That It Is Not A Constant 12 Volts.
Any Thoughts?
2002 Chevrolet Avalanche
Zotac NForce 610i ITX, 2GB RAM, 2.6 GHz Intel Pentium Dual Core CPU, 320 GB Hard Drive, 12' VGA touchscreen monitor, 3D mouse
My Worklog : http://www.mp3car.com/vbulletin/work...avalanche.html
Garry
Co-Developer of A.I.M.E.E
www.aimee.cc
Why not look for some cheapish surplus CCTV cameras/spy cameras that have composite out, and munt two composite in 4 or 5" TFT's inside the car by the A pillars in custom pods, with them being only powered when you have your headlights switched on.
you still go through the motions of checking your mirrors, but think, 3 screen upfront, how trick![]()
4x4 in a turbo stylee.
