Results 1 to 7 of 7
Thread: screen mounting?
    SMKFree liquid_smoke's Avatar
    Aug 2003
    Chicago
    screen mounting?
    Anyone seen this before
    http://www.proclipusa.com/
    http://www.easytrade.net/abm/product...015&fid=989050
    think this will work with a ds customs screen ?
    Maximum Bitrate carabuser's Avatar
    Aug 2003
    CA
    This is a good idea of attaching the screens. Easy to detach, in case you leave your car in a dangerous area. Thanks, man, most likely I'll try one of these.
    P.S. As answer to your post, I personally think the product from the first link should/will work. The second one has the list of the items that will fit, so I'm not so sure about that one.
    FLAC Skraggy_uk's Avatar
    May 2002
    Warrington UK
    Quote Originally Posted by liquid_smoke
    I made a similar mount to go in the Saab for a recased 7" console screen.
    I based it on the mounts on show at Dashmount.co.uk Clipped round a vertical vent with one screw to fix it solid. then I used a small speaker brakcet with ball adjustment from Maplin to actually fasten the screen to.
    4x4 in a turbo stylee.
    Aug 2003
    Chicago
    Quote Originally Posted by carabuser
    both links are from the same site. the site uses frames that have a different url but its basicly the same product. Actually 2 products. the vent clip and then the mount that goes on the clip for what ever your trying to put on it, different mounts for cell phones, pda, etc.
    the second link is the mount that attatches to the vent clip for a nav screen.
    i think i may go this route too, even it it dosent fit correctly at first it looks simple enough to MAKE it fit. just wanted to run it by you guys first to see if anyone has used one already or not.
    FLAC chut's Avatar
    Jul 2003
    San Antonio, TX. USA
    I bet the screens will wobble while your driving. The mount kit that came with the Xenarc does that and I am currently trying to figure out a better way to mount it in limited space.
    Peter
    Jun 2003
    I'm not being funny, but wud velcro stickies not be perfect? They r cheap, it shudnt wobble and makes the screen easily removable?!?
    Aug 2003
    Chicago
    Quote Originally Posted by way2gud4u
    Velcro may be a cheap temp solution, but i've used it in the past in my car and it does tend to wobble a little if the item has some weight to it.
    Im hoping what ever i end up doing dosent wobble, its a big concern of mine
