Results 1 to 7 of 7
Thread: TM-701l size
    Sep 2003
    TM-701L size
    I recently bought a TM701l. On digitalww.com it says it fits in a single DIN space.
    I measured the unit and it is a little larger than 7" wide, about 7 1/8".
    I thought a single DIN was 7" wide. Any one else have troubles fitting this LCD in?
    Sep 2003
    anyone.?
    FLAC chut's Avatar
    Jul 2003
    San Antonio, TX. USA
    I'm working on this right now. I am expecting my mouting kit sometime today. Did you say the kit was 7 and 1/8" Did you measure the opening in your vehicle yet?
    If the kit is 1/8" too large, I would think this just makes it a solid fit. Thats just 1/16" on each side, if it doesn't fit, force it! (gently)
    Peter
    Variable Bitrate bjm2020's Avatar
    May 2003
    Louisiana
    I have a double din setup with my head unit on the bottom and the TM-701L on top and it fit just fine. Its a bit of a snug fit but it fits.
    EPIA 800, DWW-7VGA LCD w/Touchscreen, 256mb ram, dvd rom, ati radeon 7000 video card, 80 gb 3.5" hard drive.
    Jun 2003
    also having problems
    Quote Originally Posted by biltmorerally
    I am having trouble fitting the TM701L in my Subaru Sti -2003, the car has a double din head unit that I want to replace with the monitor and another headunit. The 701-monitor is to wide when I flip it out, Arrrrgggg.
    I think I will have to strip it down and mount the bare screen in the double din space instead!
    /L-O
    C4M
    C4M is offline
    Maximum Bitrate C4M's Avatar
    Apr 2002
    Sydney, Australia
    I've found the same thing. My 701 is just a shade too wide, which means that the plastic fascia deforms a little when 'encouraged' into the DIN slot. I suspect that the manufacturers have a limited understanding of the meaning of 'DIN'.
    It's annoying, but it's nothing that some judicious sanding of the edge of the fascia (or a Gain screen) wouldn't fix.
    http://carpc.riposte.net
    I reserve all rights in connection to each post I author, without exception.
    Constant Bitrate leenas's Avatar
    May 2003
    I was surprised to when i saw it was not a single din.
    I got a 2k1 Nissan Maxima. It is definitely wide. I can get mine to fit in the hole for the slot (requires a little bending of the manufacturers braces). But the problem lies in my aftermarket face plate.
    I had to take off the plastic piece that kinda stops the screen from rolling of the tracks on the screen itself. I then recessed the screen into the hole and had to cut the sides a little of the single din slots on my face plate so that screen can actually roll through the single din hole. Its a gets a little tight at the top when the arm comes out but ill keep working on it.
    Its kinda pushing my head unit, below it, down a little and the screen almosts hits it when swinging out but it works! Its not that clean on the sides since i had to cut it but its in so i cant complain.
