Results 11 to 20 of 26
Thread: TM 701L Owners
  1. #11
    Sep 2003
    hi, this TM-701L comes with a screen right? Is it possible to just buy the housing with the motorized unit and add whatever screen we buy? Cause i notice according to the site the screen isnt vga so it wouldnt be great for smaller stuff such as gps maps right?
  2. #12
    FLAC chut's Avatar
    Jul 2003
    San Antonio, TX. USA
    Hi!
    I bought the box and sliders from Armen and installed my USB VGA Touchscreen into it.
    Peter
  3. #13
    Sep 2003
    Peoria, IL
    Quote Originally Posted by digitalww
    I started putting together the page I told you about. You can find it here: http://www.digitalww.com/VGA_Controller_howto.htm
    I will add the text shortly but this should give you an idea of the steps you need to take.
    Armen
    Could you possibly do one of those with the Touch screen kit as well. It would make installation so much easier. I would also like to see some written documentation for that stuff. I will probably be ordering both the vga and tsk at a much later date (gotta get back to the states, damn desert, find money , etc.). Thanks for the pic walk through though.
    Alan
    Carputer:
    MSI K7T turbo limited ed.
    AMD Duron 600
    TM - 701 ( Touchscreen and VGA kits will be added later)
    ATI Rage Fury
    looking at OPUS 150
    512 PC100
    40Gb HD
    SuSE 8.2 Professional
  4. #14
    Maximum Bitrate digitalww's Avatar
    Sep 2002
    ILLINOIS
    Done http://digitalww.com/TouchKitInstalation.htm
    Armen
    Quote Originally Posted by ScYThE
    Alan
  5. #15
    Sep 2003
    can someone please link me to order just the box and sliders to use any lcd. (can just attach any lcd right?)
    and does it swivel left and right?
  6. #16
    FLAC chut's Avatar
    Jul 2003
    Hi!
    no, I couldn't attach my screen. I had to decase it and install it in the new case that came with the mounting kit. I don't think there is a page for just the mount. PM digitalww on this site. He will tell you what you need to do.
    Peter
  7. #17
    FLAC chut's Avatar
    Jul 2003
    I've got a new question for all you folks. How do you attach the TM701L to your dash so that it won't slide around? I've got it in the dash, where the radio used to fit but the box doesn't fit into a single din sleeve so how did y'all attach it?
    Peter
  8. #18
    Jul 2003
    Alexandria, VA
    Quote Originally Posted by chut
    Peter
    Chut,
    I didn't have any trouble attaching the TM701L in my dash at all. It didn't fit perfectly, but I managed to use the toyota radio bracket to keep it intacted.
    You might need to create some brackets to hold the monitor in your dash, I think.
  9. #19
    FLAC chut's Avatar
    Jul 2003
    Thanks, I'm wondering if the montior box normally comes with any sort of a bracket.
    Peter
  10. #20
    Low Bitrate stkdidy ntshidy's Avatar
    Jul 2003
    california
    Peter
    no it doesnt come with any harnesses, but yes it does come with two ~4in long side brackets...too bad the case itself is the full din size
    i took the side brackets, bent them at the ends, (*note: the following is a rig*) two-part epoxied the long end to each side of the case, secured them to the case with several rows of tie straps, and screwed the other end of the brackets into a part of the frame of the car that is in the back on my dash console. its in there pretty good now. i was gonna screw the brackets into the case itself, but thought better of damaging the components
    Edit by ziplock 10/9/03 - removed offensive terms
    2005 Mustang GT:
    12w7...arc audio kar1000.2t...jl 300/4 pushng focal 165k2p...pioneer premier deh-880prs...tm-701l...audiocontrol eqs
    want: my stereo actually IN the car
