Results 1 to 10 of 10
Thread: wireless video?
    wyv
    wyv is offline
    Oct 2002
    wireless video?
    Is there a cheap way to perform wireless AV? for example, a box that takes the three standard RCA composite cables (Red/White/Yellow) and transmits the data to a receiving box that outputs the same three cables? Something that could do about 50ft range would be ok. Any ideas?
    Maximum Bitrate Seraph's Avatar
    Jun 2003
    Elmhurst, Illinois
    I am not sure but I do have a wireless colour cam that I don't use. It's the same one from digitalww (I believe). You can get it cheap from me. I have no use at the time.
    Jan 2003
    Ruston, LA
    http://www.smarthome.com/7654s.html
    they can be found cheaper everywhere
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
    SMKFree liquid_smoke's Avatar
    Aug 2003
    Chicago
    saw this just last night. Looks like a good idea. I wonder if these things will cause problems with wi-fi as it looks like this one uses the same frequency 2.4GHz
    http://store.autotoys.com/cgi-bin/wf...NAVISE651MMMTS
    Aug 2003
    Perth
    wyv
    wyv is offline
    Oct 2002
    Wow.. great links guys, just what I was looking for
    Aug 2003
    Chicago
    I wonder if anyone makes anything like this for a computer monitor. I'd love to get rid of all my cables from my 3 monitors, running under my desk.
    Maximum Bitrate gork's Avatar
    Aug 2003
    Amarillo, TX
    Those 2.4GHz video senders barf all over WiFi and vice versa. They are very wideband and highly prone to interference. Unfortunately, there's not much of a wireless video alternative as there are very few unregulated public bands with enough bandwidth for video...
    Maximum Bitrate gizmomkr's Avatar
    Dec 2000
    Smyrna, Ga, USA
    A couple of interesting things-
    Transmitting VIDEO is compleetly different than transmitting VGA.
    CompUSA sell a device by Grandtech USA that is basically the same as the Aussi link, expect not in kit form, its a finished product in a box with all the little connectors and cables.
    http://www.compusa.com/products/prod...147&pfp=SEARCH
    Oh , these guys also sell a similar set up - http://www.polarisusa.com check the wireless video section - its pricey, but looks a bit more ruged / commercial - option antennas Etc.
    I dono anyone that makes a truely wireless VGA to VGA setup (would love to find one though)
    The cheaper solution is to scan convert VGA to video , then transmit the composit signal.
    First check out http://www.linksys.com/products/grou...rid=33&scid=38
    Look at the wireless presentation gateway and player (I cant tell the difference between the two)
    A number of different companies make a prodcut to convert a VGA signal for transmition over cat 5 UPT. most of these devices DO NOT convert the signal to ethernet, only change the vga cable into UTP (and back) the more expensive devices actually convert the signal into IP/Ethernet data.
    Another route -
    Many companies make a device called a KVM switch. These switches are typically used to connect multiple computers to one Keyboard, Vga monitor, and Mouse (hence the name)
    Many of the KVM makers now have A product that converts the signal to packets (tcp/ip / ethernet) The problem now is, I have yet to find one that will convert the IP data back into an analogue VGA / keyboard / Mouse signal.
    They all make a software application (like pcanywhere or Win VNC) that runs on a client PC to connect to the box.
    If you dont mind the client pc & the software app displaying in your VGA window- it would work
    Video transmitters are comon these days - You can split the vga signal to R G B, and use a transmiter for each - then you just have the sync portion of the signal to worrie about - I dont know the specs on the sync.
    For KVM info check out http://www.avocent.com or http://www.raritan.com
    Gizmo-
    Techonlogy on Wheels
    http://www.hjnetworks.com/car
    Raw Wave kickercivic1's Avatar
    May 2003
    Florida
    did anybody try the wireless in there car? i am thinking of getting that but dont know if the picture would be just as same
