since laptops are hard to ground, I propose this:
try to somehow ground the outside of the vga connector....which connects to the laptop...which should ground the laptop..
might work
Hi, i was just wondering what the best plan of attack was for this problem, i've got my new 15" BenQ lcd grounded via a screw in the back of the case and that cured most of the noise bar some slight inverter noise, but when i disconnect the monitor cable from the laptop the noise stops, i was wondering how i should go about fixing this, can i just cut the ground wire in the cable or will this cause problems.
Damien
might work
[H]4 Life
I'm a lesbian too.
I am for hire!
Hrmm, well my laptop is grounded from the serial connecter, i've tryed grounding the whole lot from the outside of the vga connecter and still get noise, the only way i can get rid of the noise is to ground the laptop from serial connecter - car and the lcd from a screw in the back of it to same spot on car and not have the vga cable connected.
Damien
What happens when the laptop is running off bettery ?
Buy the radioshack DC-DC converter. ditch the inverter
Originally Posted by jabba
with 12v....bet the power brick puts out 12v, I bet, I bet, I bet !![]()
[H]4 Life
I'm a lesbian too.
I am for hire!
no power brick..... just the normal computer power cord straight into the monitor, id have to pull it apart to trackdown somthing like that... Is there any guides to doing it?
Damien
power brick is most likely to put out 19v. some laptops may charge from 12v, but most ive seen are 19v.
way to revive a 4 year old thread.
