Do I need to fuse TM-701L?
I've only found 1 post about fusing the 701L. I've noticed there's a 2amp in the little filter box- should I bother with another fuse between my 12v radio splice and the tft? if so another 2 amp? 5?
It wouldnt hurt, but probably not needed
thanks.
I probably won't bother. If I did what fuse rating should I put in?
Just in case somembody needs this info...I used a 5A in my fuse distrib. block. There really is no need to do this since there is already a fuse in the lcd, but the main reason is that it can't hurt and also accessilbity.
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
