On my psone I got the rca video/audio jacks on the cable
Ok but how does RCA look like???
is it the funny looking square thing that you put into the PSOne???
I don't own a PSOne just wanna use the screen.
PS. Pictures would help ALOT
There's a green coloured 3.5mm socket on the back of the PSOne display. That takes in a "Sony" jack, which is a 3.5mm plug with left audio, right audio, composite video and ground on it (not in that order).
Try see if you can find a 4 point 3.5mm plug, they're not too easy to find. I'll see if i can find the order of the points, i wrote it down somewhere... You should be able to connect your composite video signal directly into that and have it display on the LCD.
(The above is if you have a Sony branded PSOne LCD, don't know for other brands)
Thanks for the feedback, RCA is what we in Denmark call Composit
And if that doesn't work, then I'll try the "sony" jack, that starfox talks about
i'll throw in my 0.02.
I just use a regular RCA-headphone cable to get the video from a composite source to the psone screen.
see the link for a pic of the cable i use...very common.
http://ak.buy.com/db_assets/large_im...0/10265290.jpg
And if you REALLY want audio from the screen as well, just feed it in the 2nd RCA cable and you'll have mono sound.
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
