Results 1 to 5 of 5
Thread: LCD into double DIN
    Sep 2003
    LCD into double DIN
    What size is the lcd that will fit perfectly into a double din slot?
    like:
    http://www.sounddomain.com/member_pa...oyota%20Solara
    I am looking for great quality lcd's that dont dim out in daylight. What brands should I be looking at?
    Maximum Bitrate GingerPrince's Avatar
    Apr 2003
    Leeds, UK
    Quote Originally Posted by groovespacer
    like:
    I'd say it depends on how much space there is behind your dash for overlap etc. You screen viewable area may be 7" but the LCD panel may be 8". If your space behind the 2DIN slot won't take 8 inch (missus!) then you can't use that LCD.
    Numbers above are examples, not real LCD!
    Depending on what's available to you, you may consider doing what I've done. It's flush in the dash, but smaller than the 2DIN slot so I framed it. See my website link below for details.
    Sy
    GingerPrince
    Car changed for TVR Griffith 500, so computer de-installed. Using a Dension 100ix w/60Gb HD unit in the interim.
    Carputer Install - http://www.stuffandting.com/carputer/
    CarBox Software -- http://www.stuffandting.com/carbox/
    Sep 2003
    What are some reputable brand of lcd's out there? What numbers tell me if it will dim in daylight more than others?
    Apr 2003
    Leeds, UK
    Not sure on particular panels, but the most important value is the brightness, measured in nits (or c/m2 or something?) The higher the better, I think 400 are the really good ones, 250 are reasonable, anything 200 and below will struggle in bright light.
    GingerPrince
