Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: Indash monitor housing help... 7" in dash VGA conversion
  1. #11
    Aug 2003
    Orange County, NY
    I don't want to put words in his mouth... but I don't believe you you can just buy the GA700YY case from Armen, atleast from my knowledge reading this forum. Remember the 7" in dash (manual pullout) is slightly wider than normal... it might require some widening of your double din opening. I was lucky because the double din opening on my 2002 VW is slightly oversized.
  2. #12
    Newbie fierrpawz's Avatar
    Aug 2003
    Quote Originally Posted by jasonsp6
    Jason do you have pics of your setup installed in the GTI?
    I have been looking for a screen solution, waiting for indash setup. I have the rest of the project almost finished, so I need to get a screen solution. I have no prob making my own as you have if it works.
  3. #13
    Maximum Bitrate BoraXP's Avatar
    Jul 2003
    Quote Originally Posted by fierrpawz
    i have a jetta, the only thing tricky about the indash units is the fastening. fits perfect in the din but fastening it is a little tricky
  4. #14
    Variable Bitrate bjm2020's Avatar
    May 2003
    Louisiana
    If you are lucky enough to have a mounting bracket in your double din space it is a breeze to install. I have a nissan frontier and I had a mounting bracket. It is a bit too wide so I had to bend the bracket a little to get it to fit.
    EPIA 800, DWW-7VGA LCD w/Touchscreen, 256mb ram, dvd rom, ati radeon 7000 video card, 80 gb 3.5" hard drive.
  5. #15
    Oct 2003
    hi im looking at getting a DWW-7VGA, live in Australia.
    I was wondering if anyone could give me the dimensions of the housing, so i can measure whether it will fit in dash? as there seems to be some conflicting interests as to what exact size it is in this thread? thanks for the help
    glolite
