Results 1 to 10 of 16
Thread: Temperature Problems
    Newbie guvi's Avatar
    Jul 2003
    AUSTRIA
    Question Temperature Problems
    Hey.
    I´m thinking about installing a raw TFT-Display.
    But the most Specs say, that the working temp.range is between 0°-50°...
    What could happen in winter, when it´s very cold?
    tia,
    guvi
    The Spanish Style...
    SEAT LEON! My CARPC-Install or the thread up here
    Jul 2003
    AUSTRIA
    Quote Originally Posted by Enforcer
    do you get in the car when it's less than 0 degrees celsius?
    coz I sure wouldn't.
    when i get up in the morning an go to work i have to use the cold car. sure, that the temperature will rise during driving ... but what will happen at the beginning? will the screen not working?
    my car is standing the whole night outside
    Maximum Bitrate fluffy2097's Avatar
    Jul 2003
    Fremont, CA
    Try a search. This has been covered MANY times.
    A digital mind lost in an analog world.
    Learn to ask smart questions!
    http://www.catb.org/~esr/faqs/smart-questions.html
    My car PC: The Lost Cause!
    jol
    jol is offline
    FLAC jol's Avatar
    Jan 2002
    Mellansel, Sweden
    between 35 and 40 at the lowest here.
    Constant Bitrate ose-ml320's Avatar
    Oct 2003
    Baton Rouge, LA (USA)
    My Lilliput's touchscreen hasn't worked properly the last 2 mornings with temps in the 40-50F range.
    It seems the top plastic layer of the screen, which I assume is the Touchscreen, bubbles up and away from the LCD, which seems odd. I would think the plastic would contract in the cold, so I figure there is a metal frame holding the plastic film tight, and the metal is shrinking a bit causing the tension on the plastic to loosen. Problem goes away when things warm up, but it takes 15-20 minutes.
    Anyone else have this problem? possible solution?
    TIA
    Scott
    MCS-PC
    Epia M-10000
    XP Pro; 512MB; 60GB (2.5")
    Panasonic Slot SlimDVD/CD-RW
    7" Lilliput (Touchscreen)
    Casetronic C137 w/ 90W PSU (Temp)
    19V Laptop Adapter (Temp)
    Registered User
    Nov 2003
    Long Island NY
    Here in NY its been 15-20F and the screen still works fine
    Self proclaimed spoon feeder TruckinMP3's Avatar
    Jun 2002
    Colorado
    Uhm.... 0 C is = to 32F defined as the freezing point of H2O.
    The display may be sluggish untill it warms up. Any other issue would not be related to Temp.
    TruckinMP3
    Read the FAQ!
