Page 3 of 7 FirstFirst 1234567 LastLast
Results 21 to 30 of 65
Thread: Auto turnon Lilliput?
  1. #21
    Variable Bitrate Mikesz's Avatar
    Apr 2001
    Quote Originally Posted by Nic
    so does this mean i should pull apart my lilliput and short the switch? :S
    This may work, but it might also prevent any of the other buttons from working. You should test that first before doing anything.
    mike
    91 cadillac sedan deville, winXP, FV25 with Celeron 800, Redant 7" widescreen in dash, Opus DC-DC, Irman, Digital Cable remote(lots of buttons), 120 gig 7200rpm 8meg cache WD hard drive, VI power mobile HD rack, mediaengine
  2. #22
    Maximum Bitrate GingerPrince's Avatar
    Apr 2003
    Leeds, UK
    Quote Originally Posted by Michael Szilagyi
    mike
    When the power button is held in, the other buttons do not work. Thats the main reason I didn't do this, that and the lilliput needs turning off/on sometimes when it changes mode!
    GingerPrince
    Car changed for TVR Griffith 500, so computer de-installed. Using a Dension 100ix w/60Gb HD unit in the interim.
    Carputer Install - http://www.stuffandting.com/carputer/
    CarBox Software -- http://www.stuffandting.com/carbox/
  3. #23
    dtr
    dtr is offline
    Newbie dtr's Avatar
    Dec 2003
    I have mine hooked to constant power, when the computer shutsdown the lcd displays no signal and then 1 second later it turns it self off when i power the pc on it automatically turn back on
  4. #24
    Variable Bitrate NJay's Avatar
    Mar 2003
    UK
    I don't believe that is does power itself off.
    The lilliput has a red LED when its in standby. When mine doen't recieve a signal, it too displays that no video message. However the led remains green i.e its still on using full power.
    When I remove the power to it (switched via ignition), then next time its used it will revert back to Red led, i.e in standby and therefore needs the power button to be pressed to switch it back on.
  5. #25
    FLAC shakes's Avatar
    Oct 2003
    Atlanta GA
    ok ... i knew that would come up, so i went ahead and did some readings on my lilliput ... here's what i came up with:
    Amount of Current Draw:
    Power off (Red LED): 37.2 mA
    Power on (Green LED) / no signal: 260mA
    Power on (Green LED) / pc running: 550mA
    Power on (Green LED) / MediaCar running: 560mA
    recognize i have a cheap Metex meter ... it's not the best ... so these numbers may be a little off.
    My JeepPC Install
    "there are no stupid questions, just stupid people."
    "it's been agreed the whole world stinks so no one's taking showers anymore"
  6. #26
    Maximum Bitrate Altimat's Avatar
    Oct 2003
    WI
    Quote Originally Posted by NJay
    If you are using an ITPS you can use the same switched output that turns on your PC to turn on the Lilliput with a switch closure by adding a small reed relay.
    Fabricator
  7. #27
    Nic
    Nic is offline
    FLAC Nic's Avatar
    Oct 2003
    Melbourne, Australia
    260 is substantially more tha 37.2
  8. #28
    Oct 2003
    Atlanta GA
    my thoughts exactally. even if my meter is a little of ... 260 is quite a bit.
    any other lilliput owners have a nice fluke or something that may be more accurate?
    My JeepPC Install
  9. #29
    FLAC LESLIEx317537's Avatar
    Jan 2002
    Long Island, NY
    My first DennisK screen Digital COntroller board allowed you to short the button to make it turn on with power.
    I added a toggle switch that shorted it. If you add a switch that can short the power button, then when you need to change modes or change a setting just hit the switch.
  10. #30
    Mar 2003
    UK
    Yes, and in order to do that I have to take the lilliput apart which I'm not prepeared to do....
    ....well not until one of the flakey touchscreen cables or solder points give out that its
    Quote Originally Posted by Altimat
