Try turning off your TV out (both in the BIOS and in Windows drivers). My M9000 wouldn't even show the test bootup screen etc until I did this.Originally Posted by Custommx3
Ok heres a weird one. I hooked up my lilliput to my PC. and if I go to anything but VGA mode, its "over scan". IF I load my display drivers (and I know for a fact Im using the correct driver and Ive even tried older drivers) I get an error saying my display driver was writted for a previous version of windows. and it drops it to 4 bit color.
Im using an EPIA m9000. Any suggestions?
2011 Nissan Frontier SL
AMD X3 2.2 | M4-ATX | 16Gb SSD | 2GB DDR3-1333 | MSI GF615M-P33 MB
OBDPROS USB | BU-303 GPS l LILLIPUT TS | Car2PC adapter | XM Direct | USB Dual band N with custom mag-mount antenna.
GingerPrince
Car changed for TVR Griffith 500, so computer de-installed. Using a Dension 100ix w/60Gb HD unit in the interim.
Carputer Install - http://www.stuffandting.com/carputer/
CarBox Software -- http://www.stuffandting.com/carbox/
Warning, the Lilliput monitor does not like some resoution / hz combinations. Try lowering the resolution (like to 800x600) AND the hz (say 60hz).Originally Posted by Custommx3
I tried many, then it says over range. I may have to send this back.
Ensure it is 60hz, anything over 800x600 is usually over 60hz and you have to manually change it to 60hz.Originally Posted by Custommx3
did that though...![]()
I had the problem with installing VGA driver on my M10K, even on big monitor it did blackout, when restarting, then I found BIOS update on viavpsd.com and downloaded new vga driver, it helped, though vga driver has not non standard resolutions, like 848x480 (this is the best res for 7" lilliput). I am trying to find a sloution now, to twak somehow the driver to have thi res.Originally Posted by Custommx3
Zvi
