Results 1 to 5 of 5
Thread: Non-VGA Screen Advice?
    FLAC ukchris's Avatar
    Nov 2003
    Massachusetts
    Question Non-VGA Screen Advice?
    Hi all,
    I've been reading a lot about screens, all this VGA Lilliput is very exciting but for now 'm just looking for a screen that will play DVD's and maybe run video games (XBox). What would people recommend for a good non-VGA screen?
    I'm hoping to install two screens on the head restraints, the mount that fastens to the posts looks promising, not sure I want to start cutting things up to install them.
    Also, the roof mounted units, are they hard to install? Seems to me fastening anything to the roof would be tricky, in my case it's a mini-van, is there some magic mounting technique?
    Finally wires.. what do you usually do to avoid too many wires tangling around, is it hard to get them into the seats, unedr the carpets?
    Any advice would be much appricated, my plan for now is a couple of screens then an XBox for games (and maybe playing DVD's) or a pocket DVD player.
    thanks,
    Chris.
    Don't be mislead by the name... I'm from the UK living in the US..!
    Nov 2003
    Massachusetts
    bump
    Variable Bitrate MeanGT's Avatar
    Jul 2003
    Melbourne, Florida
    Well,, if you plan on hooking it up to a carputer, I HIGHLY recommend getting a VGA in screen, but if you insist on getting a non-vga screen, perhaps you should check-out the standard Lilliputs, everyone so-far seems happy with the VGA version.
    My OLD Carputer: http://www.mp3car.com/vbulletin/showthread.php?t=17412
    Currently, Don't have a carputer :( I sold my lincoln and bought a '93 Acura Vigor, plan on putting a carputer in it one of these days. You can see my vigor at: This Site
    Constant Bitrate ose-ml320's Avatar
    Oct 2003
    Baton Rouge, LA (USA)
    This is a step-by-step for a Mercedes OEM Video Display unit. Obviously it's not exactly what your looking for, but it may help.
    Scott
    MCS-PC
    Epia M-10000
    XP Pro; 512MB; 60GB (2.5")
    Panasonic Slot SlimDVD/CD-RW
    7" Lilliput (Touchscreen)
    Casetronic C137 w/ 90W PSU (Temp)
    19V Laptop Adapter (Temp)
    Variable Bitrate rgardjr's Avatar
    Oct 2003
    I installed a couple of screens in my wife's car for the kids to watch dvds on. I used the brackets that mount to the headrest and they work fine. As for screens I went the super cheap route and bought these:
    http://www.pyramidcaraudio.com/itempage.asp?model=MV7SC
    At the time Pyramid was calling these TFT LCDs, but they definately aren't. The screens are O.K. My kids don't complain about picture quality, but they aren't that great. As for wires, there is always plenty of room to run wires under the carpet or some vehicles even have channels next to the door jam that can be used. Most seat covers can be easily removed to run wires for the monitors. In my wife's Lexus the back of the seat popped off. In the Ford I just did the seat cover just unsnapped at the bottom. I could then run the wire up the back of the seat. I didn't really want to cut any holes in the seat so I just ran the wires out the top through the hole where the headrest go into the seat. Overhead displays are more difficult to install than the removable head rest route. Most of the time the over heads come with a mounting plate that is attached to the roof support pillar. Another way to go is to use a piece of 1/2" plywood or thin gauge metal one the back side of the headliner to add support and just attach the monitor to that. None if this is too difficult, but it will take some time. I use a roof mounted IR transmitter for wireless headphones to take care of the sound in my wifes car. I tried some RF based headphones, but was very disappointed with there performance. I think you should definately be looking for TFT screens.
