Results 1 to 7 of 7
Thread: What is this part called????
    Jul 2003
    So. Cal.
    I just opened up my xenarc and it broke!!!! The little metal coil had gotten stuck to the glue on the speaker and popped off and unraveled when I pulled the back off of it.
    I circled the part, the picture isn't mine, but it's the same part, same number 151 on it. What is it's name and where do I get it? Can i just pop the other one all the way off and replace it with some solder?
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Looks like an inductor coil the numbers on top will give you the value similar to the way in which capacitors are read. Try your local radio Shack.
    If the coil is unwound, winding it up and soldering back on might work, but it will not work like a new one.
    phc
    phc is offline
    Variable Bitrate phc's Avatar
    Aug 2003
    Quote Originally Posted by welthqa
    Check your dimensions with this (hope you have some calipers).
    http://rocky.digikey.com/WebLib/Sumi...0S-074-501.pdf
    It appears to be a 150 uH SMT inductor.
    Digikey P/N 308-1030-1-ND
    Manufacturer's P/N CDR125-151MC (several manufactuers will make this part, this is only one)
    Maximum Bitrate Altimat's Avatar
    Oct 2003
    WI
    Its just a coil. Solder it and glue it back on and it'll be fine.
    Fabricator
    Jul 2003
    So. Cal.
    super, I'll put it back together after I go to radio shack. thanks.
    Jul 2003
    So. Cal.
    here is a picture of my coil
    Finally got around to taking an actual picture of it. Still the same part number phc?
    radio shack doesn't have it. and digikey is going to cost me at least 7 bucks, so I really have to be sure on this.
    phc
    phc is offline
    Aug 2003
    Well, I'm sure the inductance value is correct, but the package size and or SMT footprint may be different. Study the dimensions in the datasheet and take some measurements.
    But like Altimat said, its just a coil, nothing fancier than a wire wrapped around so many turns. Just solder it back in and use some glue to keep it there.
