Just so I understand correctly, this is with the onboard video?
I don't know what has changed from the last time I tried it, but I have just managed to get my Epia M10000 onboard video to display 848x480.
I just tried to put my Voodoo 3 2000 PCI in (as I'm pretty sure it runs lots of resolutions), but my hard drive span itself down again as it tried to load Windows.
Anyway, booting back into Windows this time (without the Voodoo installed) it all loaded up fine, and I was able to select 848x480@32bpp from the "List All Modes" option in display properties/settings/advanced/adapter!
Whether I could reproduce that after a format...I don't know...but i'm gonna be chucking my Ghost boot disk in now and take an image of the drive
Oh yeah...driver version I'm using (in case it's just because of this!) is: 6.13.10.0021-01.19.01 (linked, in case anyone wants to try it)
Garry
Co-Developer of A.I.M.E.E
www.aimee.cc
Yes, this is with the onboard video on the Epia M10000.Originally Posted by rgardjr
Whether it had anything to do with the Voodoo or whether it's just drivers...i'm not sure. But i've got 848x480 on it so i'm all like
Garry
www.aimee.cc
Sweeeeeet!!
"By '16:9 support' do you mean getting 848x480 resolution? This resolution does become available when TV-out is active, it not listed on the standard resolution tab but if you go to 'Advanced' -> 'Adaptor' -> 'List All Modes' it should be there.
I downloaded a free utility called multires from www.entechtaiwan.com. With that installed it 'remembered' the 848x480 resolution and now I can switch to it even when tv-out is not active. "
This is a quote from VIA EPIA and Mini-ITX Arena forum.
I tried that and its working, but I don't like how some dialog windows are half hidden and OK, CANCEL, APPLY etc. buttons are unreachable. So I'm back to 800x600.
The native 800x480 resolution of the most 7" LCD's shouldn't have this problem. But we can't get it from the onboard video right now.
The drivers to do 848x480 with the onboard video are on the via website. It's closer, but it still doesn't match the native display resolution
Call me crazy but couldnt you edit the registry in win 9x for custom resolutions?
Well I loaded up this resolution and it didn't look very good. The bottom part of the screen was cutoff to where I couldn't see the bottom task bar. The text looked crummy too on the desktop icons. What refresh rate should I be using? I thought that 800x600 looked better, but I'm wondering if I'm doing something wrong.
To clarify the ability to select the 848x480 and 725x480 (ie usual TV modes).
The driver you are using is a much older driver than the current ones.
When I originally installed Win2K on my M10K I installed the drivers off the CD which came with the motherboard. It'd never been plugged into a TV, yet I could select all resolutions including 725x480 and 848x480 and it would display via the VGA.
When I then updated the drivers to the latest from the VIA Motherboard division, NOT ViaArena, the available resolutions change and I could only select standard resolutions. All the resolutions which are supposed to be TV only were no longer selectable without a TV plugged in.
Having the 848x480, 725x480 as selectable resolution for VGA output has been removed in the later drivers from VIA.
When using the VIA M10K and a Lilliput I always get Over Range at any non standard VGA resolution so no 725x480 etc.
Using my P4 with GF4 I can display resolutions other than the standard ones on the Lilliput.
