Could you take a picture of the inverter and bulb connector please?
Well, I took apart my screen. It was pretty easy. Now I just need to get it into that LCD holder like that one guy did.
The best I could do is flip it over and take a picture of the stuff back there. I wouldn't know what to look for, nor do I plan on removing any of the components back there. I just rearranged wires and tabs to get them out of the way. There are a total of 3 or 4 separate boards held together with connectors and soldered wires.Originally Posted by ddogg_777
afr0puff,
Since you've taken it apart, I have a couple questions for you.
In the bottom picture, how far down does the green board extend past the bottom of the lcd? Can it be moved or is it pretty much stationary? How deep is it without the casing?
I'm sure I have more questions but will wait until later.
http://www.digitalww.com/VGA_VIDEO_MODULE.htm
Why take them apart and then CRY if something goes wrong. When you can get them in parts just hook it up the way you feel like..
As for the brightness belive me anthing more, i would wear sunglases at night.!
Cheers
Mastero
