Results 1 to 8 of 8
Thread: Lilliput screen native resolution
    Nov 2003
    North Wales
    What is it peeps? Its the touch screen model from DSCUSTOMS.
    Variable Bitrate NJay's Avatar
    Mar 2003
    UK
    800x480xRGB
    Or if you want it normal LCD sales speak (i.e biggest numbers we can quote so that it looks good) its 2400x480
    Nov 2003
    North Wales
    still seems a little streched u see, thats why im asking, any ideas?
    Mar 2003
    UK
    It will be stretched if you are using std resolutions that a PC uses, eg. 640x480, 800x600, 1024x768. These are all 4:3 ratio resolutions. The lilliput will display them but much like a widescreen TV it will stretch them across the whole screen and hence will look fatter.
    You need to setup you resolution so that is has roughly 16pixels across for every 9 pixels down, i.e 800x480 rather than 800x600 which is what I'd guess you're currently using.
    HTH
    Oct 2003
    Lilliput Resolutions
    I got my Lilliput last week and spent Friday getting the thing setup. I got 1024x786 working but it looks to small. When I try 800x480 or 800x600 I get an "over range" message from the LCD. I tried sending the same resolutions to my desktop monitor and it works so I think my video card is sending the correct data.
    Anyone have any words of wisdom. I'm using Powerstrip to set the custom resolutions.
    Raw Wave Laidback's Avatar
    Oct 2003
    Madrid
    Quote Originally Posted by gwlund
    SEARCH for posts by "NJay", he seems to have done a lot of testing with different resolutions
    Oct 2003
    The only resolution that gives me a "almost" perfect 16:9 screen is 848x480@75hz.
    First this resolution didn't work but after doing a reset (can be found in the menu of the lilliputscreen) it worked !
    zvi
    zvi is offline
    Constant Bitrate zvi's Avatar
    Jan 2004
    Tbilisi, Georgia
    Quote Originally Posted by Wizardtm
    What Mobo/video are you using? I cant get this res on CLE266 (M10K onboard video), I am already ****ed off
  1. Lilliput screen + MKM1150 ¿?
    By XaCoSo in forum LCD/Display
    Last Post: 11-15-2003, 02:19 PM
  2. Lilliput resolution? 16:9?
    By detz in forum LCD/Display
    Last Post: 11-07-2003, 04:05 AM
  3. Replies: 4
    Last Post: 10-25-2003, 05:29 AM
  4. Most common screen resolution?
    By Wesson in forum Newbie
    Last Post: 10-16-2003, 09:35 PM
  5. Anyone know about Lilliput 7" XGA Touch Screen
    By koyoutou in forum LCD/Display
    Last Post: 10-06-2003, 12:37 AM
