Results 1 to 10 of 11
Thread: Lilliput - Playing DVD's in 16:9
    Oct 2003
    The answer to this is probably right in front of my face but can someone tell me the trick to playing DVD's on the Lilliput in 16:9 wide screen mode so the picture fills the screen (no black bands on top/bottom)?
    FLAC cproaudio's Avatar
    Aug 2002
    so cal 2 hours from everywhere
    It has nothing to do with the screen. You need to set your video card to display wide screen such as 848X480, 1024X600 or 1280X768
    Edit: My FV24 is displaying 848X480 and tere's no black bars top and bottom when playing DVD unless its 2.35 aspect ratio. I do get black bars on the sides if I play 4:3 movies but I can always zoom in and still keep the original aspect ratio.
    NEW complete and updated My project with 100+ pics on 7-4-03
    If you have a Shuttle FV24 motherboard in perfect working condition for sale, please PM me.
    Nov 2003
    North Wales
    The lilliput wont do that resolution though
    Oct 2003
    Resolution
    I am running 16:9 aspect ratio (800x480) and still black bars. There has got to be a setting for the video card/DVD software that's telling the LCD to use 4:3 mode. Anyone?
    Constant Bitrate blicky_1's Avatar
    Sep 2003
    North Hampshire, United Kingdom
    Quote Originally Posted by gwlund
    I have found that different DVD's do different things, some are full screen and some you get the black bars........Is there anyway you can change the settings in ME to stretch?? as in Windvd or Powerdvd??
    Oct 2003
    The lilliput screen is 16:9 and NOT cinematic widescreen so in most movies you will get upper and lower black bars.
    Some movies are 16:9 and will fill the whole screen including most animated disney movies.
    This is the same for regular widescreen TVs.
    You can artifatually stretch the image using aspect ratio control but the image will stretched or compressed.
    The whole explanation is here:
    http://widescreen.org/widescreen.shtml
    HTH
    Alric
    Mar 2003
    WVA
    It all depends on the DVD and how it is coded.
    Some are "Anamorphic" widescreen and some are "Cinema" widescreen. I believe the Anamorphic dvds have been specially coded to display on 16:9 screens with no black bars.
    At least that is what happens on my 56inch HDTV (Widescreen) at home. Monsters Inc. shows perfect in full mode with no black bars... but Saving Private Ryan shows small black bars in the same mode. It all has to do with the dvd.
    Click Here to see my Car's Website
    2003 Nissan Sentra Spec-V
    FLAC DodgeCummins's Avatar
    Oct 2000
    DFW area
    The quick explanation is if it is Anamorphic Widescreen or not.
    Anamorphic has only the image data, and the player fills in the black lines at top or bottom if shown on a 4:3 screen. If shown on a wider screen the bars disappear.
    Regular wide screen has the entire image plus black bars as part of the 4:3 image file. Those, the player "zooms in" and puts the edges of the image at the full width of the display and crops out the black bars if it is a wide screen.
    The difference is simply resolution. The Anamorphic has for example say 500 lines of data within the visable image...the non-anamorphic has the same 500 lines, only it includes the black bars...so the actual movie image has less resolution than the anamorphic movie image.
    However, if you have a correct wide screen setting, and go full screen on the player program, you shouldn't have a problem with the display.
    Jan 2004
    Quote Originally Posted by cproaudio
    How was you able to get the onboard S3 twister to allow you to use 848x480 res. No matter what I try the only choices i'm getting are 800x600, 1204x768 etc. I've tried using Powerstrip but the "custom resolution" button is greyed out on me.
    Any idea's?
    zvi
    zvi is offline
    Constant Bitrate zvi's Avatar
    Jan 2004
    Tbilisi, Georgia
    Quote Originally Posted by Gillious
    Any idea's?
    I have the same problem, I got into registry, edited everithing there, but did not help. my liliput shows 640x480 streched, though I have connected it to my desctop pc with Geforce2, set the resolution (driver supports it) 848x480@75Hz and it is perfect, but not on onboard VIA VGA........
    any ideas??? :-)
  1. VIA EIPA 800 to output 16:9 resolution
    By rmjjensen in forum LCD/Display
    Last Post: 11-18-2003, 05:15 AM
  2. 16:9 with WinXP
    By Der Me!$ter in forum LCD/Display
    Last Post: 11-11-2003, 06:34 PM
  3. Lilliput resolution? 16:9?
    By detz in forum LCD/Display
    Last Post: 11-07-2003, 04:05 AM
  4. Lilliput LCD monitors
    By 001 in forum LCD/Display
    Last Post: 10-27-2003, 03:46 PM
  5. 7" screen, which mobo/gfx to buy for 16:9 TV out?
    By Vittel in forum LCD/Display
    Last Post: 08-08-2003, 01:15 PM
