Results 1 to 10 of 18
Thread: Mounting a Lilliput
    FLAC ukchris's Avatar
    Nov 2003
    Massachusetts
    Mounting a Lilliput
    How are people mounting their screens? Do you use the stand and put it on top of the dash, hang it from the dash?
    Also has anyone done their own roof mounting, seems a little scary to me, I have visions of screws sticking out of the roof of my car..!
    Chris.
    Oct 2003
    I was wondering the same! My screen should arrive within a week. Mounting it on the dash seems a good idea in my car - but I'm worried about the attraction a clearly visible screen has on criminals..!
    A quick dismount option which enables me to put it in my (locked) dashboard in 5 secs would be great... but how? There will always be cables that have to be connected/disconnected...
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    at the moment I have a pioneer AVD W6010 which is stuck on top of the dash. It is the quick relewase version and is just a TV screen.
    I have just got a lilliput VGA Touch, this is currently set up indoors as a second screen on my main PC while I test it out. I am planning on putting it into the dash rather than on top, although i may put it on top for a while, but I am concearned about theft, and it won't be so quick release as the pioneer.
    The thing is I have to find places to relocate my head unit and Climate control before I can install in the dash.
    Oct 2003
    I have the same dilemma. In the meanwhile I am controling my carpc from my Palm T|T using bluetooth and VNC.
    The Vauxhall Vectra Project ccsnet's Avatar
    Jan 2003
    Morecambe, Lancs, UK ( Just For The Moment )
    I haven't got mine yet and I'll be having the same problem... how ever if you want to check out the gallery on my site ( see below ) may be that will give you some ideas.
    I would like to find out what standard the mount is then go from there, I think its the same as a flash gun mount on a camera ?
    Terran
    Jan 2003
    Hi guys.. found this...
    Originally Posted by russ
    does anyone recommend a good air vent attachment/ mount for the screen. I've searched and only found ones for PDA and I'm not sure if they are any good
    Hi russ,
    I purchased one of these screens from cartft.com last week and had the same great service you got (and yes i was very impressed with the screen also!!)
    Mount - did not like the one that came in the box as it was not a quick release one, went down to my local car audio shop and picked up a quick release bracket from a VDO navigation system?? fits perfectly mounted on a DIN blanking plate (moved HU down) blanking plates 5ish bracket 20ish (ish coz my mate works there and got them for free!!) Screen is in the perfect position in my car and is still adjustable if i need to tilt as there is a thumbnut on the side.
    Regards
    blicky_1
    in here Lilliput 619GL-70NP (XGA) withTouchscreen purchased in UK from carTFT.com
    Terran
    Constant Bitrate blicky_1's Avatar
    Sep 2003
    North Hampshire, United Kingdom
    Quote Originally Posted by ccsnet
    Hi russ,
    Regards
    blicky_1
    Terran
    Check out my pictures in "show off you project" under Mercedes install UK
    Any questions please contact me, i will try and get some better pictures up here for the weekend.
    Regards
    blicky_1
    Sep 2003
    Lots of people seem to be interested in these brackets!!!
    I will try and source some from my supplier if you are interested, please let me know.... (UK only)
    Check back here and i will let you know cost and avalibility....
    blicky_1
    Sep 2003
    Hi all,
    I have found a supplier for you as mine can't supply this cheap!!
    http://search.lycos.co.uk/searchFram...6etemp%3Derror
    You will just need to use the one on the left, throw the other one away.
    Let me know how you all get on...
    Regards
    blicky_1
    Variable Bitrate danon's Avatar
    Oct 2003
    Queensland, Australia
    Quote Originally Posted by ukchris
    Chris.
    Stand is a no-no to me, carputer should be a total integration between car and a computer, for me that's the whole idea. Look at the left, that's my setup. It's a hacked PSOne screen, I wrapped the circuit using a static bag, (the one you got when buying computer components) with two silica gel placed inside to protect it from humidity. All this is hidden so it doesn't matter if it's ugly, the most important is the screen.
    screws wont stick outside the roof as your car as it would have a space of about an inch or two from inside. It only depends on how strong the inside roof of your car is, mine isn't that strong so I didn't mind hanging something in there in case it falls during a bumpy ride.
    [....99.9%]
    [HW] 566eMHz/128mb/6gb, FlyVideo3k, RandMgps, M1-ATX, 7" Lilliput, VGA2AVadptrFor2ndVideo, 4CH/100rms, 10"Sub, 40AhDeepCycleTank
    [....99.8%]
    [SW] XP/MMC/FP:D3,FlyTV/AxifeFM,CarMM?
    [Working on] puttingBackEvrythg.
  1. Lilliput Sources - USA
    By ukchris in forum LCD/Display
    Last Post: 11-22-2003, 05:42 AM
  2. Car Adapter For UK Lilliput Users
    By blicky_1 in forum Power Supplies
    Last Post: 11-13-2003, 07:41 PM
  3. Lilliput +cheap +composite
    By eminence in forum LCD/Display
    Last Post: 10-31-2003, 03:52 PM
  4. Methods of mounting?
    By MP3DUB in forum General Hardware Discussion
    Last Post: 10-01-2002, 06:40 PM
  5. car mounting kits
    By Shaggamuki in forum Off Topic
    Last Post: 09-19-2001, 07:49 PM
