Smoke some weed! that's what I'd dooooo!Originally Posted by gerard
working on my custom install i dismanteled my liliput an i managed to kill both white retaining clips that hold the band cable in place from the controller to the screen.
i enjoyed my screen for one day only.
what now ?????
time for the sig:
'00 VW golf TDI upped to 130 HP - 18" RS 6 wheels - liliput 7" tft in indash housing - epia 10K - SB audigy - caliber 1 fahrad CAP - RF punch amp - hollywood 1.6K mono amp - boston acoustics pro - RF 10" DVD sub
BossTone74
Ouch, tough luck. Take a bunch of pics and post them, maybe someone have good ideas what to do.
If not, we might prevent killing our own screen if we know what not to do when taking it apart. I planned on taking mine apart out of curiosity, but i think i will wait....
Retaining clips? How would that destroy it? Post pics so we better understand.
ill try to shoot some tonight
the clips lock the band cable in place in the holder with the actual connections in it, without it wont position properly.
be very carefull when making them loose,the one on the motherboard slides to the side aproxx 3 mmto open, the one on the panel flips open 90 degrees to open.
time for the sig:
For every problem there is a solution.....
Post some pictures and perhaps there is an easy solution for your problem.
Can't you use your soldering iron and some wires to reconnect te board?
there are about 50 wires in the cable, a hair thick and a hair apart so i dont think thats an option.
i can work very precise, have great equipment (electronic engeneer) but i think matters will go to worse.
i have a old 7" lcd with the same with connectors, i am going to try to modefy the connectors to fit those of the liliput ones.
also sent a desperate mail to cartft.com, maybe they can take some of a brokens screen or something.
time for the sig:
hey gerard,Originally Posted by gerard
i bought a liliput and i'm going to be dismantling it and putting the guts into a different enclosure. do you have an update on your situation? any advice?
thanks,
kuo
Hot Glue.... As long as you never want it back off again.
??? Worth a try.
Old School MP3CAR.com member!
I would try the hot glue option that dscustoms mentioned. A friend and I had the same problem with a xenarc screen a while back and the only way we could get the ribbon to stay in without the pressure from the clips was to insert the ribbon with the broken clip ... apply pressure and drown it in hot glue.... when we turned it on it worked fine, but never try to remove the glue because it might peel the circuit away from the board. ... You could also try the Digikey catalog www.digikey.com for a replcement ribbon connector. Good luck and I hope it works out.
