Page 1 of 4 1234 LastLast
Results 1 to 10 of 33
Thread: Got carputer working tonight... and...
    Low Bitrate spectrumzz's Avatar
    Sep 2003
    Well, yay it was the first night of running my carputer fully in the car while driving, and I have observed several things.
    1) The lilliput is too bright for night use. The brightness control doesn't seem to do anything, which makes it hard to use. It blinds your nightvision.
    2) My VGA cable is not well enough shielded, or the power supply is "dirty". Probably a combination of both, but a bit of "pattern" occurs with it. I'm not happy about shelling out another $100 for thick cable.
    3) The carputer is distracting, especially when using the GPS. I figure it makes you much more prone to an accident. In fact, anything expect playing mp3s was distracting.
    4) My LCD mount is rock solid, and I'm happy about it, but it leans into the passenger's space.
    5) I feel prone to car theft now, with the LCD in plain view. The in-dash system didn't work for me, so I had to go with a mounted screen, but I'm afraid to park it anywhere.
    Looking back, I'm not sure the time I spent writing my own software and building all the cables for the car PC was worth it. I'm tempted to just stop now and sell off the parts, even though it's working.
    Nov 2003
    UK London
    Hi Spectrumzz,
    Sorry to hear that you are having a few problems with your screen.
    The only part I can maybe help with is that I have used a GPS system in my car for quite a while (going to be upgrading to the full carputer hog).
    When I first put this in and mounted the GPS (Streepilot III) on the dashboard and in my field of view. What happened is that it became completely confusing and distracting - felt like I was going to crash everytime I paid it a little attention! If I had to zoom in and look up a route this was even worse - max out - brain overload!
    However after a while (and this really is my opinion - nothing grounded in science) is that my brain adapted to this extra stimuli(us) and now I can glance and reroute the GPS with very little effort or distraction.
    The feeling that I have now with the GPS screen is that it had become part of the driving experience rather than a bolt on. So stay with it a little while to see if it improves.
    I'm sure others can help with some of your other points too.
    (I know others here have used a low-tech way of reducing the brightness/glare with a Red screen overlay which cuts down on the night adaption being destroyed by the screen.)
    Good luck :-)
    Russ
    Aug 2003
    Houston, Texas
    When I had the Clarion AutoPC 310c installed in my car with GPS it had a warning about driving conditions when using the GPS while driving. I'm sure I felt the same way at first but once you get used to it and you don't look at it all the time you should be okay. I mainly glanced at it every now and then when I saw that my field of view of the road was clear (less to no traffic) and the road didn't zig-zag like a madman. All-in-all it worked out fine as most GPS systems in cars. The voice informing me of with a countdown of "1.x miles turn left/right onto (streetname)" helped out alot in my travels! I guess it just depends if you're willing to get over the newness of the "carputer" idea and use it like you would a new stereo in your car rather than trying to watch it all the time while driving!
    Raw Wave Laidback's Avatar
    Oct 2003
    Madrid
    I just wear sunglasses!
    Raw Wave hijinks21's Avatar
    May 2002
    Albany, NY
    if you keep it in your car and are still scared of theft.. take a picture of everything. Most insurance companies won't believe you put in your own computer and a lcd in dash
    '98 Explorer Sport
    80% done
    Newbie CoolDaddyAndy's Avatar
    Sep 2003
    Oak Creek, WI
    If it is too bright try experimenting with window tint. dont adhere it permenantly until you are satisfied. Try different shades of tints to get the best result. If the screen runs hot on the display surface they may not be a great idea (the tint may bubble up like you see on cheap installs on car windows) but if it is relatively cool, this should work.
    Also try darker and duller colored themes for windows and the same skins for what ever media player you use. As for your GPS program there shold be a night display option. Use it.
    I hope this helps a little, just thought I would share my 2 cents...
    SMKFree liquid_smoke's Avatar
    Aug 2003
    Chicago
    what i do or what i did do for the couple days my screen was working.
    At night, i would keep the screen turned off until i needed to use it. If i wanted to change some mp3's that were playing, turn it on, make the change and turn it back off so i can not be tempted to look over at the lcd while im driveing. Seemed to work out great for me. Stopped all the people looking into my car as i pass them to see what that screen was. Some people would even follow me to pull up on the side and see what the screen was. Cool and not cool, cause you really dont know what they are thinking or there intentions are. In the day time i leave it on.
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    have mine working day or night, MP3's and GPS, don't really have a problem.
    Haven't fitted the lilliput yet, I have a Pioneer video screen, which can look bright, but it doesn't worry me.
    Maximum Bitrate bertybassett's Avatar
    Sep 2003
    Gloucester (UK)
    when not have the screen saver set to blank at a wait time of 1 min ? At night time it will blank the screen hence no glare problem?
    Oct 2003
    Madrid
    Thumbs up
    Why not use MediaCar? It dims at night!
  1. Good time to buy carputer components?
    By Linus in forum General MP3Car Discussion
    Last Post: 11-25-2004, 08:57 PM
  2. Full carputer stereo replacement? Opinions Welcome.
    By jasonsp6 in forum General Hardware Discussion
    Last Post: 12-26-2003, 11:42 PM
  3. Thinking of selling my old carputer for an ipod
    By churnopol in forum General Hardware Discussion
    Last Post: 10-15-2003, 10:10 AM
  4. help - starting up carputer
    By tilezzzzz in forum Power Supplies
    Last Post: 06-18-2003, 12:52 PM
  5. motorized screen stopped working :(
    By corsamel in forum LCD/Display
    Last Post: 11-26-2002, 10:52 AM
