Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: Lilliput touchscreen prevents standby
    Oct 2003
    Using an Epia-M motherboard I get a "prevent standby fron touchkit" error everytime I attempt to standby from a Lilliput.
    Anybody else had this problem?
    Thanks,
    Alric
    Nov 2003
    computer standby
    I get the same problem with the touchscreen drivers for my lilliput. Trying to find newer drivers that might prevent it, otherwise I won't be able have my laptop go to sleep. Also waking my laptop from the touchscreen doesn't work. I need to press the keyboard. Any ideas out there?
    Low Bitrate nijel's Avatar
    Nov 2003
    MI, US
    Quote Originally Posted by Alric
    Thanks,
    Alric
    I have that problem with XENARC. I emailed EELY USA, the touchscreen manufacturer, and they told me they know about the problem from other customers and they wanted from me to send them my entire system for testing. I haven't heard from them since I told them its my carputer and I can't send it to them. So there is no new drivers resolving the problem.
    But I found a temporally resolution that works well for me. If I disable the touchscreen from the Device Manager I can put the carputer in Standby and it comes out of Standby with no any problems and touchscreen working. But if I need to restart it I have to enable and disable the driver again which is not a big deal cause I have a remote and keyboard as well to do that.
    So you can try that if you don't need to restart often.
    Jun 2003
    Chicago
    Thanks,
    Alric
    I saw this on digitalww.com...
    #7. Touchkit USB controller driver will prevent the system standby for Windows 98 first edition.
    Workaround: Do not let system standby.
    Ok, who is NOT using Win98? This appears to be a fundamental problem with the USB driver.....I hope they fix this..standby is a necessity for the carputer.
    Oct 2003
    Well, I am running XP with all updates and it still does it.
    Maximum Bitrate Altimat's Avatar
    Oct 2003
    WI
    I am running XP with all updates and it works great. I can also wake my laptop from standby by touching the screen. I used the updated drivers available on the digitalww site. The included drivers are supposedly an older version.
    Fabricator
    Jun 2003
    Chicago
    Quote Originally Posted by Altimat
    Altimat, did you purchase your screen from digitalww? Some say the Lilliput is too bright at night..what do you think?
    Oct 2003
    WI
    Quote Originally Posted by EBJUSTIN
    Screen was from Ebay. Unfortunately the CarPC hasn't migrated from the bench to the car yet, so I havent tested the brightness driving. I expected the night feature in MediaCar would work well enough, but then I read about controlling the backlight voltage with a pot. When its done and I start really struggling for mods maybe I'll try that idea.
    Fabricator
    Maximum Bitrate bertybassett's Avatar
    Sep 2003
    Gloucester (UK)
    Yeah I get the same problem with the lilliput or digitalww drivers?
    I'll try rebuilding the system some time and see what happens but till then I'll just have to suffer.
    Oct 2003
    Angry
    hmmm, errors when attempting to install the drivers at digitalww. Also if I try to just update the drivers it tells me that drivers are not newer than what I had.
    I wonder if there is a direct download from the manufacturer?
  1. Lilliput Touchscreen Problem : Help!
    By spaced_chris in forum Input Devices
    Last Post: 01-29-2004, 01:16 PM
  2. Lilliput touchscreen drivers HELP PLEASE
    By CDesigns in forum LCD/Display
    Last Post: 11-24-2003, 04:42 PM
  3. Lilliput Touchscreen From carTFT.com
    By blicky_1 in forum LCD/Display
    Last Post: 11-08-2003, 05:56 PM
  4. speaker next to lilliput touchscreen. clever?
    By sham in forum LCD/Display
    Last Post: 11-02-2003, 05:47 PM
  5. Whats easier? Touchscreen or not to touchscreen?
    By jodathmorr in forum General Hardware Discussion
    Last Post: 10-21-2003, 12:22 AM
