So I guess no one here has a lilliput?
I got my lilliput screen in the mail yesterday. 7" TFT Touchscreen.
My question is, in the user manual, the FIRST line says "Do not remove the back of this screen!"
In many of the installs I've seen, the back of the screen is removed. What is the reson for this? Is it really necessary? If so, do I need to do anything special when installing it? i.e. some other kind of protective backing on the circuit board
Thanks!
its just there that you dont grab into the backlight inverter which hurts a lot
remove at own risk
time for the sig:
'00 VW golf TDI upped to 130 HP - 18" RS 6 wheels - liliput 7" tft in indash housing - epia 10K - SB audigy - caliber 1 fahrad CAP - RF punch amp - hollywood 1.6K mono amp - boston acoustics pro - RF 10" DVD sub
Do you really think no one here has a lilliput ?So I guess no one here has a lilliput?
Anyone got pics of the inside of a lilliput?
+ tons of other threads
And also there to show you that if you open it up, you will void your warranty.
actually that was sarcasm. I did a search. nothing relevant came up. what would you suggest I search for?Originally Posted by cvi
I could see the sarcasm. I try to answer your questions here, but i think you would have to ask another kind of questions if you want answers that are usefull.![]()
Limited space maybe?In many of the installs I've seen, the back of the screen is removed. What is the reson for this?
Not if space permitsIs it really necessary?
Good ideaIf so, do I need to do anything special when installing it? i.e. some other kind of protective backing on the circuit board
Depends on what you wanna findwhat would you suggest I search for?![]()
Rephrase the Q's and answers might come.
and again .............![]()
