Results 1 to 8 of 8
Thread: paint XENARC 7 inch
    Constant Bitrate BOND007BE's Avatar
    Jul 2003
    belgium
    paint XENARC 7 inch
    howdy ,
    i own a xenarc 7 inch touchscreen ,
    my question , i HATE the silver color , i want to paint it black.
    any tips on opening xenarc and for painting it ?
    tia
    bond007
    the sun always shine
    Raw Wave Confused's Avatar
    Aug 2003
    Essex, England
    It's pretty simple to open up, just 6 screws. 1 in each corner on the back, plus 2 on the bottom edge (tiiiiny little silver ones that hold the mounting bracket)
    Once you are inside, it's 2 screws to hold the controller board on (along the bottom edge) and then the screen/touchscreen overlay is held down by 4 screws, 2 on either side, which have little metal "clips" that go over the edge of the screen.
    The buttons can then come out, they just pull out from the back, or push them from the front.
    Re-installation is opposite of pulling it apart Just make sure you line up the touchscreen overlay and actual lcd panel in the centre of the gap
    Garry
    Co-Developer of A.I.M.E.E
    www.aimee.cc
    Apr 2003
    Quote Originally Posted by BOND007BE
    howdy ,
    tia
    bond007
    I'm thinking of doing the same with my silver Lilliput screen. Opening it is really easy. I figured a can of black spray paint should work on the front and back housing, but how about the buttons ? The ones on the Lilliput are reverse silk-screened, the words are transparent and the buttons glow a cool blue when you press them. I could spray the buttons black and re-label them using Letraset adhesive lettering or similar, but I would lose the cool blue glow.
    Any other ideas ?
    Jul 2003
    belgium
    thanx for the info
    about painting , just spray it over , or first sanding , primer and then final coat ?
    May 2003
    Vancouver, BC, Canada
    Use a primer designed for plastic parts. You definately DON'T want the paint to start flaking off.
    Goto your paint shop and ask for plastic primer.
    Vic
    2000 Toyota Celica with Carputer
    Jul 2003
    belgium
    before attaching primer do i need some sanding ? FINE
    do you have a brand name for plastic primer ?
    Aug 2003
    Essex, England
    It shouldn't need any sanding, just make sure you give it a good clean, to get rid of any finger prints or anything else
    Just go to local shop and ask for a can of plastic primer, brand won't matter much at all
    Garry
    www.aimee.cc
    Apr 2003
    I just painted my Lilliput black using nothing more than a can of Tamiya TS-14. This is a synthetic lacquer specially formulated for use on plastic. There is NO need to apply plastic primer as the monitor already contains a coat of silver colored paint.
    The monitor looks really nice in black - and the buttons look good and match well in their original silver color.
  1. DigitalWWW TM-710VG vs. Xenarc 700YYV
    By sq_geek in forum LCD/Display
    Last Post: 08-12-2003, 10:14 PM
  2. FS: Xenarc 700TSV touch UXGA capable
    By cproaudio in forum Classified Archive
    Last Post: 01-20-2003, 07:38 AM
  3. Xenarc Meta FAQ
    By Skippman in forum LCD/Display
    Last Post: 08-23-2002, 04:11 PM
  4. Xenarc 7" Touchscreen VGA Group Buy.
    Last Post: 07-27-2002, 11:52 AM
  5. Removing paint sucks
    By wizardPC in forum Off Topic
    Last Post: 07-01-2002, 02:23 AM
