Results 1 to 10 of 12
Thread: Regulate Power to LCD?
    Dec 2003
    Birmingham, AL
    Do I need to regulate the power to my LCD? And if so, if there a piece of hardware somewhere that you recommend to do this?
    I will be using a Xenarc touchscreen with a PIII laptop.
    thanks in advance,
    .brit
    Raw Wave hijinks21's Avatar
    May 2002
    Albany, NY
    how are you planning on powering the laptop anyway?
    '98 Explorer Sport
    80% done
    Dec 2003
    Birmingham, AL
    Quote Originally Posted by hijinks21
    I had originally planned on running a 12V source into the laptop, but I just checked the specs on the AC adapter for the laptop and it outputs 18V.
    How do I get 18V from a 12V source without using a AC/DC converter?
    Also, what do I use to regulate the power to the LCD?
    thanks,
    .brit
    Variable Bitrate NJay's Avatar
    Mar 2003
    UK
    Use a cigarette lighter multivoltage Laptop adaptor which replaces the mains brick you normally plug into you laptop. If you want to install it permanatly then just unsolder the wire going to the lighter plug tip (12V+ positive) and surround (earth) and wire them into 12V+ and earth source in you car. I say only the tip and surround as most 12v -> 16/17/18/19V laptop adaptors have the electronics in the lighter plug
    HTH
    Constant Bitrate parawing742's Avatar
    Jun 2003
    Tennessee
    I run my Xenarc screen unregulated, but I get tiny white flashes all over the screen when I do so. I working on a better solution right now.
    Phillip Hullquist
    I entertain people through adventure movies.
    www.11visions.com
    Constant Bitrate blicky_1's Avatar
    Sep 2003
    North Hampshire, United Kingdom
    I am using two regulated psu's from Maplins, a 12v>15/16/17/18/19v adjustable for the laptop (£20) and a 12v for my Lilliput (£10). I checked both of these using a meter and putting the car under different loads see if voltage moved up/down too far, both were minimal. Both have been installed for over 6 weeks now with no problems. Both are using the original cig lighter ends, i have used female cig lighter sockets (£1 Maplins) to connect to battery and ignition lines. The screen psu switches on/off with the ignition key.
    FYI the laptop psu has been left connected overnight sometimes with the laptop still running and car has started no problems. Makes me wonder if it is worth going the 12v/240v invertor route to install a full tower PC as the laptop was only supposed to be a temp measure!!
    Regards
    blicky_1
    Mar 2003
    UK
    Blicky_1 which ones are they from maplins?
    Dec 2003
    Birmingham, AL
    Sources of power supplies?
    Anyone know any good sources for adjustable DC power supplies online?
    thanks,
    .brit
    Sep 2003
    Quote Originally Posted by NJay
    N59AC LAPTOP Car ADAPTER now £14.99!
    UG32K Universal DC Adaptor £9.99
    Both are regulated and usually in stock
    FLAC shakes's Avatar
    Oct 2003
    Atlanta GA
    doesn't the xenarc come with a cig adapter to power it? that regulates the voltage right? just chop it up and hard wire it into another source.
    My JeepPC Install
    "there are no stupid questions, just stupid people."
    "it's been agreed the whole world stinks so no one's taking showers anymore"
  1. LCD won't signal MB to power RCA out
    By tropez in forum LCD/Display
    Last Post: 10-23-2003, 04:13 PM
  2. lcd power
    By traitorhound in forum LCD/Display
    Last Post: 07-17-2003, 05:44 PM
  3. Doubt before buying an power acoustik lcd screen
    By cyrofilho in forum LCD/Display
    Last Post: 06-01-2002, 10:40 PM
  4. LCD power question
    By BRINET in forum LCD/Display
    Last Post: 04-20-2002, 01:34 PM
  5. LCD power, which pin?
    By dudah85 in forum General Hardware Discussion
    Last Post: 05-10-2001, 06:35 PM
