Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: Lilliput: Have to calibrate every 5 minute?
  1. #11
    Oct 2003
    I got a reaction from CarTFT, I can send it back - great service there .
  2. #12
    Nov 2003
    Quote Originally Posted by Burat
    I'm assuming they said it was broken??
  3. #13
    Variable Bitrate Batmanatthenewb's Avatar
    Sep 2003
    Newark, Ohio
    Wherea re you guys going to do the calibration. I can't seem to find it.
    Sam
    Batman@TheNewBatcave.com
    AMD XP 2000, 1gig PC2700, 80gig 7200RPM HD, DVD CD/RW, ATI All in Wonder 8500DV w/remote, DataChute, IRDA, Wireless 802.11b, cell modem, Lilliput 7" VGA TS, XP Pro, GPS w/Routis
    www.samshomepage.net
    www.Cars-N-Computers.com
  4. #14
    Low Bitrate Richie's Avatar
    Sep 2003
    Sweden - Stockholm
    BUMP! This thread needs to continue... I've now got my Liliput to work... Though the CD-program TouchKIT or whatever doesn't work... Tried on 3 CPUs now it crashes on them all... So I cant't calibrate... help?
  5. #15
    Low Bitrate Crav4Speed's Avatar
    Nov 2003
    New York City
    Quote Originally Posted by Richie
    Try these drivers:
    http://www.egalax.com.tw/Download.htm
    Here's the thread that started it:
    Thread
    You posted in there...
  6. #16
    Sep 2003
    Sweden - Stockholm
    Thanks alot dude! Now it works perfectly... Now I'll just have to learn how to calibrate...
    Quote Originally Posted by Crav4Speed
    Try these drivers:
    Thread
  7. #17
    Banned RPM_VR4's Avatar
    Nov 2004
    L.A.
    I cannot get my TouchKit to work. Please help!
    History: When I first got it, I tested it a bit on my work PC and it was fine. After that it sat on a shelf for about 4 months while I was too busy to work on my CarPC. When I installed it in my CarPC, it was exibiting the current problem (below), but after trying about 10 different drivers I got from all over the place, I got it working most of the time (It would still exibit the current problem sometimes, but would fix its self after 5min or so). After about a month with it like that, my HDD crashed. After re-installing XP on a new HDD, I have never been able to get it to work in 3 months except twice it just started working for about 30 seconds and then started having the problem again.
    Problem: 25 point cal is zig-zags all over the place, but mostly in the lower left corner. When I touch the screen on the right side, the pointer usually jumps somewhere in the middle, and then quickly flys over to the lower left corner. I have tried every driver I can find including digitalww's and the ones in this thread.
    Do I need to replace the touch-screen material, the PCB, both, or can someone suggest a way to fix what I got?
    Thanks,
    -Ryan
  8. #18
    Nov 2004
    L.A.
    Also, does it matter which way you connect the 4-pin from the plastic to the wire that goes to the PCB? I have tried both ways. It is currently the way on which it worked for 30 seconds those 2 times.
  1. Replies: 5
    Last Post: 02-28-2004, 12:45 PM
  2. Replies: 2
    Last Post: 12-11-2003, 11:36 PM
  3. Lilliput audio inputs/outputs
    By Cinco5 in forum LCD/Display
    Last Post: 12-10-2003, 03:54 PM
  4. Lilliput composite input flashing?
    By Misanthro in forum LCD/Display
    Last Post: 12-09-2003, 04:58 PM
  5. Lilliput ghost
    By spectrumzz in forum LCD/Display
    Last Post: 11-26-2003, 06:18 PM
