you have to shake it like those little kid toys
cant remember the name of them
right after testing and gettin everything working I put my lilliput in the car- the rather bodged power button I wired on (external rocker switch) had come loose inside so I opened it up again and stuck the wires back on. now the switch works but when I turn the unit on I just get backlight and blue leds and no image -I couldnt see any loose wires inside any ideas? the menu doesnt come up or anything. -im guessing this cant be a vga input (or lack of it ) problem as I cant even switch to RCA input. what is the likely cause? Im guessing broken /disconnected wire between the actual lcd and the board inside the lilliput. as it seems to turn on and I get a flash of blue led if I press anything.
etch-a-sketch, and hopefully he's just kidding :-SOriginally Posted by SjLucky
2006 Chevy Colorado: VIA M10000 EDEN, 1 GB RAM, 80 GB 2.5" Seagate HDD, USB Slim Slot DVD/RW, Holux GPS, MobileVU 10.4" LCD (touch not working yet), VOOMPC Case (blue), 70W DC-DC supply.
v helpful
is your lilliput broken? i will buy your casing off you![]()
