Results 11 to 20 of 22
Thread: Liliput instal problems :(
  1. #11
    Maximum Bitrate digitalww's Avatar
    Sep 2002
    ILLINOIS
    Raise your Refresh Frequency from 60 to 75 and it should work right away.
    Armen
    Quote Originally Posted by Richie
    Restarted, installed soft of TSK, plugged it, it was recognized and all drivers were correctly install, but now I have no picture (like I hade from the beginning of my laptop)
    My carpc is set to give 60Hz and CRT display out the VGA-port so everything SHOULD be okey, right?
    "OVER RANGE"
  2. #12
    Low Bitrate Richie's Avatar
    Sep 2003
    Sweden - Stockholm
    Quote Originally Posted by digitalww
    Armen
    Tried all frequencies @ 800x600 and 1024x768... :/ OVER RANGE all of the times... And never over range on my laptop :/
    edit: haven't restarted the CPU after each time I changed that detail... (do I have to?)
  3. #13
    Sep 2002
    ILLINOIS
    I test all my lilliputs at 75 @ 1024x768 and they all work. When it is at 60 @ 1024x768 I get the over range.
  4. #14
    Sep 2003
    Sweden - Stockholm
    Nope... :/ Didn't work niether... And I'm shure that the Liliput works since I just have to plug it in the laptop and I get picture... MUST be something else? What board do you use?
  5. #15
    Oct 2003
    Cool Resolution problems
    I have mine running with crazy resolutions...works perfect. I have mine set to 70hz actually at 1024x768...at *16 bit * color. Try 16 bit color! Also...you might want to try turning off and on the Liliput to see if it resyncs. Let us know how it goes.
  6. #16
    Newbie bajaguy's Avatar
    Nov 2003
    San Diego, CA
    Anybody using this screen with the onboard VGA of the M1000? Mine only wants to work at 800*600 @ 8 bit I switched the refresh to 75 already. Thoughts?
    Ben
    Project Postponed!
  7. #17
    Raw Wave Laidback's Avatar
    Oct 2003
    Madrid
    Quote Originally Posted by bajaguy
    Ben
    Yes! I had to go check the settings because I just stuck the monitor on and it worked straight off, I think I just up'd the color, 800x600 , 60Hz, 24 bit on M10000.
  8. #18
    Newbie Frenchy's Avatar
    Dec 2003
    France
    I presume you didn't forget to activate the VGA output of your laptop...
    just kidding...
    Did you try to switch off the Lilliput, and turn it on again when you got the "over range" message ?...I know that it worked fine for some Carmedia.org members whot met the same problem....
    Regards,
    Frenchy.
  9. #19
    Sep 2003
    Sweden - Stockholm
    Now I will go for cristmas-holidays! Tnx for the help so far I'll get back after cristmas and try to fix it then... BYE!
    (and a marry cristmas 2 y'all!)
  10. #20
    Variable Bitrate Goose's Avatar
    Dec 2002
    Europe
    on epia M1000 8nemiach core) the only refresh I get to work is 60hz.
    i run my in 800x600 @60Hz and i am happy with that
  1. Hard drive shock problems.
    By Mikesz in forum General Hardware Discussion
    Last Post: 03-21-2005, 04:37 PM
  2. Problems, Problems. Need some support.
    By mhermann in forum General Hardware Discussion
    Last Post: 04-22-2004, 08:59 AM
  3. touchsreen problems on lilliput
    By mrzigzag in forum LCD/Display
    Last Post: 12-03-2003, 03:57 PM
  4. Liliput Vs Xenarc
    By masterlp in forum LCD/Display
    Last Post: 09-25-2003, 11:36 PM
  5. sv24 video problems again
    By Holden__V8 in forum General Hardware Discussion
    Last Post: 01-06-2003, 10:00 AM
