Results 1 to 10 of 17
Thread: Smaller than 7" VGA Widescreen?
    Dec 2003
    I'm in the final planning phase for my carputer and need some help with this...
    I'm looking for a widescreen VGA LCD smaller than 7". It will be mounted in a standard double-din radio slot that is about 1/2" too small for the 7" I looked at. The whole thing needs to be smaller than 7"x4" because it will need to fold down to allow access to the DVD behind it. I have no problem taking the housing apart if the panel/controller are smaller than 7"x4"...I will probably do it anyways for aesthetic reasons.
    I've tried ing and came up with a few possibles but not exactly what I'm looking for. All of the 6.4" and 6.5" VGA's I found are standard ratio, not widescreen. I'd even go for a 7" it would fit in a 7"x4" space. This is the last thing I need to decide on so please help!!
    Maximum Bitrate carabuser's Avatar
    Aug 2003
    CA
    What car do you have? Cuz it looks like I have the same problem but if I take the housing apart it'll fit just fine
    Current Status: For Sale
    Specs
    - 1.5Ghz Toshiba Laptop (available - no screen)
    - Indash Motorized 7" VGA TS
    - DeLorme GPS (sold)
    - Power Inverter (sold)
    - Pioneer HU (sold)
    Dec 2003
    It's a 2003 Hyundai Santa Fe. From the measurements I've found for the Xenarc the panel itself is about 4.5" tall and I only have 4" of room. If I didn't need it to fold down, I wouldn't have any problem with it.
    Maximum Bitrate Seraph's Avatar
    Jun 2003
    Elmhurst, Illinois
    Have a look at the screen from digitalww. according to the specs, it's only 6"x3 3/4"ish without the trim. I am talking about the hitachi screen.
    - Lwin M. Maung
    If it's stuck, force it. If it breaks it needed replacing anyway
    Aug 2003
    CA
    I was gonna say hitachi too, but it says it 106mm, which is still over 4"
    So looks like we're pretty much screwed. I would suggest going for indash one. A bit expensive tho
    Specs
    - Pioneer HU (sold)
    Jun 2003
    Elmhurst, Illinois
    True. I was looking at the active area. Sorry.
    - Lwin M. Maung
    Aug 2003
    Milwaukee
    Yeah your pretty much left with custom molding the dash like I did. Actually, you should all have a much easier job. Its not that difficult really.
    Dec 2003
    I have an idea but I'm not sure if it'll work. What I'm thinking of doing is allow the bottom to move up/down...so when it opens up, after the top clears the dash the bottom will raise 1/4" to allow it to lie flat and provide access to the DVD. Then when it closes, it just sinks back down again so the top can clear the dash.
    Do you guys think this idea would work? Of course, I'd still prefer to have one that would actually fit but if need be here's an alternative.
    Variable Bitrate Mikesz's Avatar
    Apr 2001
    Quote Originally Posted by jagreen2
    Sounds like a lot of work. I would purchase a flip out screen if it would fit. If you have only 4" it may be hard to fit it and your DVD drive if the DVD is also din sized. You could also simply put the DVD someplace else.
    mike
    91 cadillac sedan deville, winXP, FV25 with Celeron 800, Redant 7" widescreen in dash, Opus DC-DC, Irman, Digital Cable remote(lots of buttons), 120 gig 7200rpm 8meg cache WD hard drive, VI power mobile HD rack, mediaengine
    Dec 2003
    I won't be using a head unit or anything like that. My whole carputer will be mounted in the double din slot in the dash. I can't use the in-dash screens...I won't have enough room for it and everything else.
    I'd really like to just use a 6.5", 6.4" or even 5.6" widescreen VGA monitor but I'm getting the feeling they don't make them. The only ones I have found are not widescreen so they won't fit
  1. VGA vs Composite 7" widescreen
    By freestyler in forum LCD/Display
    Last Post: 07-31-2003, 05:31 PM
  2. 4 SALE -- Xenarc 7" Widescreen VGA + 3 RCA Inputs!
    By JBCrash in forum Classified Archive
    Last Post: 05-02-2003, 05:15 AM
  3. 4 SALE -- Xenarc 7" Widescreen VGA + 3 RCA Inputs!
    Last Post: 04-01-2003, 02:16 PM
  4. 7" widescreen VGA
    By Whaleboy in forum LCD/Display
    Last Post: 07-08-2002, 03:07 PM
  5. 7" Widescreen VGA LCD for $499!?
    By kgoode80 in forum LCD/Display
    Last Post: 07-07-2002, 07:31 PM
