Results 1 to 3 of 3
Thread: Bigger Icons/Fonts with Lilliput & XP...no squinting!!
    Nov 2003
    Marietta, GA
    Our friends in Redmond have given us XP users a nice way to increase the size of our window elements (window scroll bars, icons, icon placement, application font size, etc, etc). This is REALLY useful when you are using a 7" VGA screen in a car.
    This stuff is hidden in:
    on dekstop, right click/Properties/Appearance/Advanced/Item:....then select the "item" you would like to change. Play with (click up or down on the "size" select box) things like Icon (size, vertical & horizontal spacing, scrollbar, Caption Buttons, etc, etc).
    Eventually you will end up with all of you desktop, application, and folder elements much bigger on this tiny screen. This way you can use a higher resolution screen setting without having to suffer with TINY icons, scrollbars, text, etc).
    The attached screen shots are from my CarPC running VGA/Lilliput in 800x600.
    Enjoy!!
    MikeH
    Low Bitrate StratusPh34r's Avatar
    Nov 2003
    Atlanta, GA
    This is a good tip, and not exclusive to Windows XP users...all Win9x/NT/2000 users can do the same.
    Nov 2003
    Marietta, GA
    You're right! I just discovered that my W98 machine has this same capability. I guess I just never needed it on a 15" monitor. Thanks!
    MikeH
  1. Difference between Windows XP Home & XP Pro?
    By grandamp3 in forum Off Topic
    Last Post: 02-21-2003, 06:07 PM
