Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: Small Lilliput display problem
  1. #11
    Nov 2003
    I think it's a syncing isssue. Mines does that once in a while. When I cycle the power for the lilliput, it syncs up and is fine.
  2. #12
    Oct 2003
    Well the USB-touchscreen drivers wherent the problem... Tested the screen with and without drivers installed... Havent played with it a lot, was on vacation for a week..
    The problem is occuring in each res & hz setting, as soon as it goes from loading -> windows, blank screen until I power off/on the screen... (or plug / unplug the vga-cable)
    If its a sync problem, then why is it fixed after power off/on and why does it occure in all res & hz's ?
    Something must happen during the switch from 'standard' -> 'windows' resolution switch... I'm going to try a small app which will switch windows resolution from 800x600 -> 1024x768 -> 800x600 (with 1s intervals, 5s after windows bootup) to see if that fixes anything...
  3. #13
    Jun 2003
    Memphis - TN
    Turn off your TV out in the bios.
    set it to CRT only.
    2011 Nissan Frontier SL
    AMD X3 2.2 | M4-ATX | 16Gb SSD | 2GB DDR3-1333 | MSI GF615M-P33 MB
    OBDPROS USB | BU-303 GPS l LILLIPUT TS | Car2PC adapter | XM Direct | USB Dual band N with custom mag-mount antenna.
  4. #14
    Maximum Bitrate ddogg_777's Avatar
    Apr 2003
    HOT Arizona
    Quote Originally Posted by Custommx3
    set it to CRT only.
    Tried... anything else? I got this problem too.
  5. #15
    Jan 2004
    Kentucky
    hmmm this worries me.. I was also planning on buying a lilliput screen... But this is kind of bothering me.. I dont want a screen that is gonna be a pain in the arse...
  6. #16
    Oct 2003
    Well other then this, I have no problems with the screen at all...
    Going to make the screen-resolution switch program tonight, see if that helps... It kind of sucks because I have to unplug the car-pc for this... No wireless network yet, and no cd-rom/usb-key...
    Currently I just wait for the PC to bootup, then start the car (which will make the screen lose power for 1s), then everythings fine This will just cause problems when I'm going to make the screen use the power from my Opus though...
  7. #17
    Nov 2003
    Anybody figure this one out? I have to cycle my display everytime I turn on my carputer!!
  8. #18
    Banned NightHunter's Avatar
    Dec 2003
    Milwaukee, WI
    Adjust your refresh rate. It is probably to high or low.
  1. Lilliput LCD, 2000 Celica GT and voltage problem
    By Goose in forum LCD/Display
    Last Post: 12-29-2003, 05:53 PM
  2. Replies: 2
    Last Post: 11-05-2003, 04:01 AM
  3. Display problem in ME
    By cjones in forum ME Archive
    Last Post: 03-11-2003, 11:01 AM
  4. looking for small 2.5 x 2.5 inch display
    By edie209 in forum LCD/Display
    Last Post: 05-04-2001, 04:29 PM
  5. problem with monitor/LCD display
    By seven10split in forum General Hardware Discussion
    Last Post: 08-12-2000, 07:46 PM
