Results 1 to 10 of 14
Thread: Looking for CAD Files for Lilliput
    Low Bitrate crosseye's Avatar
    Dec 2003
    Syracuse, NY
    I am in the middle of designing a few in-dash and pull-out/motorized DIN solutions for the 7" Lilliput Touchscreen LCD. Right now I am in the brainstorm phases but I would like to start playing around with ideas on 3D CAD software so I can work spatially (it's much easier to undo a mistake on the computer than with materials ).
    Has anyone run across CAD Drawings for this screen (preferrably 3D)? Or, has someone been ambitious enough to draw them himself? Any leads are greatly appreciated. I have plenty of CAD experience, but I don't have the accurate measuring tools at my disposal... otherwise I'd draw it myself.
    I'm more than willing to post my solutions online as CAD files or exported JPG's to help people with ideas. Probably much better than a scanned in sketch or quick Photoshop sketch.
    Dec 2003
    Syracuse, NY
    Anyone, anyone... Bueller?
    Aug 2003
    Sorry, I own a xenarc...
    but what do you plan to do with your designs? is this for yourself or for a commercial endeavor? Will you mount the lilliput with its housing or strip it out? How will you build the molds etc?
    I am very interested in motorized vga screens and will be willing to help depending on what you plan to do so MORE INFO PLEASE........
    Dec 2003
    Syracuse, NY
    Quote Originally Posted by A_C_K
    I have a couple good ideas for fabricating a manual 1-DIN fold out for a VGA screen. The design (still just in my brain) would be easily modified for motorized extension and retraction. I would probably leave the LCD in its housing and use a mount.
    Mainly, this was going to be for myself and to share with the group, but depending on how successful it is, maybe I'd fabricate and sell them too.
    I guess the overall basic design of the thing would be the same when using different LCD screens, just the way they were mounted to the unit would be different. This would probably be the best solution so i don't have to mold additional housings.
    Dec 2003
    What software do you have? I could probably knock up a basic model in Solidworks (only have 98 version though), as I am thinking of something similar for my beemer. That will probably be in the air vent location though, and I'm trying to think of ways to route the air flow around it and having it looking stock when not in use. Like you I have ideas in my head but getting them to work in reality is always another matter
    I think my lilliput is around 2-3mm wider than my head unit on each side though, so you may have to think about removing the housing. That would help in reducing the weight and stress on your mechanism, important for vibration, stability etc.
    Dec 2003
    Syracuse, NY
    Quote Originally Posted by tekta
    Yeah I just noticed that the casing on the Lilliput screen is slightly larger than the width of a 1-DIN slot. I was thinking my stock head was the same width as 1-DIN but it isnt. I'm probably going to end up removing it from the housing... which renders the need for a CAD drawing of the housing.
    Maybe I can get my rough ideas down this weekend and show you. Do you want to send me a pic of your dash outlining where you want your screen? I'll keep it in mind when desiging mine.
    Definitely keep in touch though... we'll bounce ideas around.
    Jan 2004
    Tekta: I've just done some work on an install for my E46. Not sure what you'r driving, or if you have Nav, but what I did was move my heating controls to where the eyeglass cubby is. I moved my cubby to where the heating controls are. I had to cut the back off, and trip the sides of the cubby, but I can fit the Lilliput in there. I'm going to look at how I can fabricate a pull out for the Lilliput. If you get something working, drop me a note. I'll do the same.
    Nov 2003
    Marietta, GA
    phc has posted some CAD files here.
    MikeH
    phc
    phc is offline
    Variable Bitrate phc's Avatar
    Aug 2003
    Quote Originally Posted by MikeH
    I have good models of the LCD panel and the LCD controller board and USB touchscreen board, but not of the case. In my application, I removed the case (actually sold it to someone) and made an aluminum bezel.
    Time to update my web pages.
    -Patrick
    Dec 2003
    Syracuse, NY
    Quote Originally Posted by phc
    -Patrick
    100% what I was looking for. Thanks SO much.
    PS. I have a moderately well-functioning manual pull out "prototype." Needs some tweaking then to be placed into a 1-DIN case.
  1. EXTINF files?
    By Kevin in forum Software & Software Development
    Last Post: 09-11-2009, 04:48 AM
  2. Can't seem to play any video files
    By ptdalen in forum ME Archive
    Last Post: 07-03-2003, 06:57 PM
  3. After I copy files, they are corrupted.
    By Cliff in forum Software & Software Development
    Last Post: 05-17-2003, 09:49 PM
  4. Girder exported control files
    By ddt in forum Software & Software Development
    Last Post: 11-30-2002, 06:20 PM
  5. Girder .GXR files
    By renierv in forum Software & Software Development
    Last Post: 01-21-2002, 06:35 PM
