DUH!
The answer was in the link that I posted
sorry!![]()
Im thining of getting a Lilliput screen for my new setup (http://www.action-replay.co.uk/Mobil...ts/Monitor.htm). but Im going to want to run Gentoo if at all possible, is the usb touch screen compatible in linux?
cheers
DUH!
sorry!![]()
Have you gotten this to work with Gentoo? All the drivers I've seen are binary only. Thanks.
Tom
1993 Probe GT
Rio Car w/20gb
Link no worky.. what was the result? Linux drivers?
-Chris
Here's an updated link:
http://www.action-replay.co.uk/Mobil...en_Monitor.htm
They have Linux drivers but I'm pretty sure they're binary only. So that means unless you have the specific distro that they made it for (i.e. Redhat 9.0) you're out of luck.
Tom
1993 Probe GT
Rio Car w/20gb
I am in the process of writing them for the 2.6 kernel. They will be open source of course.
I already have userspace code to talk with the touchscreen, so the only trick is making that into a kernel module. If all goes well, it will be done in about a week or two.
If you want to drop me a note, I will email you when I finish. tomh at yourmom dot sh.
--Tom
ME-6000, Lilliput 7" vga + touch, generic GPS, RedHat 9, custom mapping software.
Just a quick update-
After about 100 kernel panics, I finally have a kernel module that talks to the lilliput touchscreen. Now I just have to hook that into the linux input subsystem, write a few ioctl, and I will be done. It should be all downhill from here. (still might take a week or two with school and all)
For those of you waiting for the driver, it will be a 2.6 driver only.
Anyways, I will post again when I have a driver for you all to try out.
--Tom
I, as I'm sure many others, will be eternally grateful if you can get this done. Thanks so much for the effort.
Tom
1993 Probe GT
Rio Car w/20gb
The drivers from eGalax for fc2 will work with Gentoo with little tweaking.
Matthew
Mitsubishi Lancer Hatch
VIA EPIA 800V
128RAM - 10 GB HDD
200 Watt PSU - 300 Watt Inverter
Lilliput 7" Touchscreen
D-Link USB FM Radio
Dlink DWL-520+ b/g Wifi Card
Fortuna GPSmart
Alpine Amp and Splits
Gentoo Linux/Windows 2000
Anyone had any success on getting the Xenarc/Gain to work under Slackware?
BMW 325i -01
Computer hardware:
VIA Epia MII 10000 Nehemiah 256MB/160GB
Casetronic Travla C158
Gain 7" TS
USB GPS
Opus DC-DC 150W
Software: Frodoplayer and Mapmonkey
Sound system: Front kit: DLS UP6, Rear: DLS 425 Powered by DLS RA40
