Results 1 to 4 of 4
Thread: "Touch kit" killed my device manager.
    Low Bitrate TheSpecialist's Avatar
    Jan 2004
    NJ
    Looking for anyone who can help me figureout what happened and how to fix it.
    I received my Lilliput touch screen and installed drivers that I downloaded from www.egalax.com. Finally the touch worked and life was good. Then I attempted to update a different driver and learned that I couldn't open device manager it said system32\devmgmt was missing or corrupt. I replaced the file and got the same error message. I reimaged the harddrive to make sure the problem didn't exist prior to installing the Touchkit. The device manager worked fine, so I reinstalled the TouchKit and the same thing happen. In addition it also won't let me do a find or search.
    Mini-ITX 533 Eden
    512MB Ram
    48GB LT HD
    XP Home
    USB = KBD & Mouse
    Any ideas?
    Jun 2003
    Memphis - TN
    why dont u do a system restore?
    2011 Nissan Frontier SL
    AMD X3 2.2 | M4-ATX | 16Gb SSD | 2GB DDR3-1333 | MSI GF615M-P33 MB
    OBDPROS USB | BU-303 GPS l LILLIPUT TS | Car2PC adapter | XM Direct | USB Dual band N with custom mag-mount antenna.
    Jan 2004
    NJ
    I have done so much on setting up everything on that harddrive that I'd hate to dump it. The problem seems to be that anything I try to run with a .MSC extention won't run. I tried to do a Windows repair and it won't except my admin password.
    I checked out your website, what does that power supply you used go for?
    Nov 2003
    Marietta, GA
    Specialist...do a search for Lilliput drivers on this board....I believe this is a common problem.
    MikeH
