The switch still needs to be momentarily closed to turn it on or off, even if you power it from the ignition (unless you use the remote). I have a small reed relay on my ITPS switched (logic low) output, and I use the momentary switch closure to turn on/off both my Lilliput and my laptop. I think this is an excellent application for the ITPS when you own a Lilliput. If you already have a PSU, you can distribute the load by running the Lilliput and an external DVD drive from the ITPS 12V output and limit the load on your PSU to your CPU/HDD etc.
LinkBack URL
About LinkBacks
I don't plan to use the other buttons, but I kept the board and mounted it to the back of the display. I did need the IR receiver and extended that from the board to the back side of my dash panel.
