Page 1 of 4 1234 LastLast
Results 1 to 10 of 38
Thread: Extension cable for Lilliput touchscreen...
    Constant Bitrate NotchbackVW's Avatar
    Jan 2004
    UK
    I am looking for the round 9 pin connection for extending the input to my Lilliput screen. I am unsure of what the connector is called! Can anyone elp me so I can search for it. I need one soon! Dont want to guess and waste money.
    Cheers guys.
    Newbie matqua's Avatar
    Dec 2003
    Australia
    I believe it is a mini din 9 pin, http://www.tmz.com/wrx/lilliputLCD.html remember?
    Hope this helps
    Quote Originally Posted by NotchbackVW
    Cheers guys.
    Matthew
    Mitsubishi Lancer Hatch
    VIA EPIA 800V
    128RAM - 10 GB HDD
    200 Watt PSU - 300 Watt Inverter
    Lilliput 7" Touchscreen
    D-Link USB FM Radio
    Dlink DWL-520+ b/g Wifi Card
    Fortuna GPSmart
    Alpine Amp and Splits
    Gentoo Linux/Windows 2000
    Raw Wave wizardPC's Avatar
    Jun 2000
    Nashville
    holy crap thats awesome!
    Debt as of 1/1/05: $34,354.48
    Debt as of July 4, 2007: $0.00 explanation
    Total spent on wedding so far: $3885.79
    Thanks to everyone for your support.
    I'M DEBT FREE!!
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    I too wanted to extend my Lilliput, couldn't find a lead anywhere. In the end I had to buy a 9pin mini-din lead to bare ends and solder the female 9pin mini-din on myself.
    Got the bits from RS components
    http://rswww.com/cgi-bin/bv/browse/M...stockNo=463495
    http://rswww.com/cgi-bin/bv/browse/M...&stiboID=17310
    http://www.rs-components.com/
    Oct 2003
    Springfield, MO
    why dont you do what i did? i bought a VGA extension cable and a USB 1.1 extension cable. just extend the touchscreen USB cable and the VGA cable! simple if you can't find that other cable. walmart has the cheapest USB extension cable and Circuit city has the cheapest VGA extension cable. good luck!
    (this may also work for the usb plug that plugs into the side of the monitor for the video inputs. i havne't tried it yet but i will try it very soon!
    Low Bitrate telstargb's Avatar
    Aug 2003
    Leicester, UK
    Quote Originally Posted by Shaar
    Thats what I did too, and the output is just as good as before the lead was extended, but I must admit that my 1st thought was to extend the din connector end, until I found out that the plug/socket was not readily available.
    telstargb
    Mondeo 1.8 Zetec : Epia 800 : 60gb drive : Lilliput 7" VGA : Sapphire USB GPS : Opus 90w : WinXP : Road Runer : Destinator
    Jan 2004
    UK
    Gone with enforcers route just ordered two solder yourself mini DIN male and femail connecters and 4 meters of shilded 9 core cable. Enforcer and I are UK and RS has this stuff, dont know if us does too.
    Considered extending both serial and usb end but seems neater to extend just one cable and connections than two.
    Cheers everyone...........
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    The reason I went this way, is because I had to feed the cables through some tiny spaces, and trying to run two cables, one with a relatively large connector, was going to be a real pain in the rear.
    Oct 2003
    Springfield, MO
    yea i understand that. i dont have much of a space restriction becuase i'll be running the cables under my center console between the seats and its easy to run cables of any size through there.
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    That's what I've done. but it is a ***** to do unless I remove the front seats and carpets.
  1. To extend my 5 wire touchscreen cable or not?
    By e_fractal in forum General Hardware Discussion
    Last Post: 11-07-2003, 05:31 PM
  2. 10' VGA extension cable
    By Bbrian in forum General Hardware Discussion
    Last Post: 09-03-2003, 02:49 PM
  3. FS: Touchscreen w/ Touch Controller and Serial Cable
    By Mp3Goose_Your King in forum Classified Archive
    Last Post: 01-15-2003, 12:22 PM
  4. LCD extension cable ThinkPad 560
    By hakan in forum LCD/Display
    Last Post: 03-22-2002, 08:36 AM
  5. Can't get VGA extension cable to work...
    By SuperMatty in forum LCD/Display
    Last Post: 01-14-2002, 05:07 PM
