Results 1 to 4 of 4
Thread: liliput pcb thickness
    Maximum Bitrate tolisn's Avatar
    Dec 2003
    Greece
    Can anyone inform me of the thickness of the pcbs and the lcd of the lilliput LCD screen? I am designing (while I am waiting for my screen) a new case and I need the thickness of ONLY the pcbs and the lcd mounted together (no speaker). The original thickness of the case is 26mm. I am trying to make this thing as slim as possible to fit into my Mazd6.
    Thanks in advance
    May 2003
    Quote Originally Posted by tolisn
    Thanks in advance
    The screen is already pretty compact, but u can remove some mm if u want to. The screen is about 6mm and the pcb about 1-1,2cm. But remeber the cooling.
    Dec 2003
    Quote Originally Posted by mrzigzag
    dont these thing run pretty hot? have you consider any ventilation for long term reliability of the screen?
    Dec 2003
    Greece
    thanks alot with your help
  1. Opus 90W: PCB module or Open frame?
    By dormouse in forum Power Supplies
    Last Post: 10-01-2003, 02:04 PM
  2. Liliput Vs Xenarc
    By masterlp in forum LCD/Display
    Last Post: 09-25-2003, 11:36 PM
  3. How do some PCB boards require no PSU?
    By vash in forum General Hardware Discussion
    Last Post: 08-26-2002, 06:21 AM
  4. Sproggy MK2.8 PCB for 8$ FULL ATX FEATURE
    By Mastero in forum Classified Archive
    Last Post: 06-29-2002, 02:33 AM
  5. trimming down seiko L2014 PCB
    By chrisbrown in forum LCD/Display
    Last Post: 05-10-2001, 09:37 AM
