Results 1 to 10 of 13
Thread: Did i F#@ up my Xenarc Screen
    Sep 2003
    Question Did i F#@ up my Xenarc Screen
    Hi guys, i just finished up 3 weeks of bondo/sanding madness and when i tried my screen out today it was malfunctioning. The funny thing is that it worked find the day before. But all of the sudden the AV1, AV2 work fine. However, when the PC comes up, it shows the resolution but does not show what's going on the screen. It's just blank. Has anybody else had this problem?
    I checked the connection on the screen with the black VGA cord but it seems to be connected fine. I'm really depressed because my dash for my civic is all integrated but now the LCD doesn't work properly. I think i'm going to cry ;-(
    FLAC shakes's Avatar
    Oct 2003
    Atlanta GA
    does it malfunction only when it's in the dash? this guy around here molded his xenarc into his dash and it ended up pressing down on one of the corners ... makeing the touchscreen wig out.
    just wondering if there could be something about the way it's installed ...
    My JeepPC Install
    "there are no stupid questions, just stupid people."
    "it's been agreed the whole world stinks so no one's taking showers anymore"
    Sep 2003
    malfunctions everywhere
    No, i have sitting on my desk and it is malfunctioning, but i probably did something to screw it up. I'm just wondering how to fix it. It shows the resolution 1024* by whatever, or 800 by 600 but nothing on the screen. However when i connection some video through AV1 or AV2 everything works fine.
    thanks,
    Gary
    FLAC robiewp's Avatar
    Dec 2003
    Massachusetts, US
    sounds like the computer output might be the problem? try dropping the frequency, etc...
    No other thoughts
    car computer rev 5: 8" lilliput and usual suspects
    Sep 2003
    What do you mean frequency?
    I tried different resolutions, and nothing works. It all worked before, i'm really lost. I have this dash piece that's all integrated into my dash. I custom made it for the xenarc, but now it lookes like i F'd it up. I know software but not hardware, so i really have no clue as to how to fix this problem. But if i by a new one it would have to be another xenarc, since i don't know the dimension of the lilliput and it probably won't fit perfect into the bondo project i did to my dash. But it looks like liliput is a better screen.
    I'm really F'd! plus my girl friend dropped my laptop the other day and know it's making noises, but that's a story for another day. Anybody have any ideas, anybody experience similar problems?
    Dec 2003
    Massachusetts, US
    i was speaking of frequency. Tell us the results of doing this:
    go to desktop, right click, click properties. Go to the settings tab. Click advanced. Go to the 'adapter' tab. click "list all models". scroll to the VERY TOP of the list and click the item there (should be lowest res, freq, and color) Then click ok,ok,ok,etc, and tell us what happens. If this doesn't work we're pretty much guarenteed the problem is on the computer.
    Sep 2003
    ok did all that, i picked 640x480 at 256 colors, the xenarc screen showed that i was using that resolution at 60hz , but no pictures. When i select AVI or AV2 it works fine (NTSC) signal it show moves from dvd fine. So i guess somehow i messed up some part of the vga thingy. Any other ideas. I tried it on a whole bunch of computers and it didn't work. but worked fine a couple of days ago...
    Constant Bitrate kalito's Avatar
    Nov 2003
    ny
    have you tried booting up on save mode... try it maybe you have some kind of conflict, and see if it works fine with a regular screen or a different one. and if you tried everything else just pop it open and see is any broken wires..
    Sep 2003
    hardware issus not software
    Quote Originally Posted by kalito
    hey thanks for your reply. But it some kind of issue with the xenarc screen, Eveyrthing worked before, i have tried it on several different comptuer and different resolutions but nothing gives, like one of the controller cards is messed up or something. Any ideas on how to fix it, where to take it too?
    please be specific if you can help, thanks
    Oct 2003
    Atlanta GA
    if av1 and av2 work but the vga does not, i'd guess there may be something wrong witht he vga comtroller board. different circuitry is used for the composite and vga inputs.
    do you know someone else with a xenarc that you could put your screen on their controller board?
    My JeepPC Install
  1. Replies: 3
    Last Post: 03-03-2005, 08:44 AM
  2. Xenarc screen doesnt work.
    By zijester in forum Input Devices
    Last Post: 02-24-2004, 12:02 PM
  3. FV24 and Xenarc wide screen driver How to
    By cproaudio in forum LCD/Display
    Last Post: 03-15-2003, 01:16 PM
  4. xenarc screen
    By the_spy_guy in forum LCD/Display
    Last Post: 11-15-2002, 11:58 PM
  5. FS: Xenarc 7" VGA touch screen
    By rdliou in forum Classified Archive
    Last Post: 09-27-2002, 09:44 AM
