Page 6 of 8 FirstFirst 12345678 LastLast
Results 51 to 60 of 77
Thread: Lilliput install in and Impreza, Lilliput issues
  1. #51
    FLAC LESLIEx317537's Avatar
    Jan 2002
    Long Island, NY
    Quote Originally Posted by phc
    Thanks LESLIEx317537 & wi77iam for the info. My 2004 is probably the same as the STI since the antenna is in the window. I'll be hooking up my Dlink USB radio in the next week or so.
    Any ideas on where to get an antenna cable extension? I'd like to put the Dlink under the seat next to the amp to keep the analog cabling as short as possible.
    -Patrick
    I plan on moving my USB FM to the trunk area along with my Sound Card.
    I bought this at the AID Auto store for 6 buks:
    SP13000|M2-ATX|512MB DDR400|2.5" 7200RPM S-ATA|Trans-7"|Slim SL DVD-CDRW|KEH 5.1 DSP|SB L!ve Ext|Gyration PowerMate|BT|WiFi|GPS|WinXP|VoomPC
    GPSing - Digital Speedo
    Relocating headunit and extending faceplate
    Button app to Alt-Tab between two programs
  2. #52
    Maximum Bitrate wi77iam's Avatar
    Jun 2003
    Chester Springs, PA
    My Dlink is also in the trunk. I connected a thin coax line directly into the antenna amp located inside the left rear pillar.
  3. #53
    Jan 2002
    Long Island, NY
    Quote Originally Posted by wi77iam
    If you don't mind can you show me the picture of your connection or where the antenna amp wire is in the trunk? I know that the antenna amp box is on the rear deck where a left deck speaker could go. Is that what you connected it to?
  4. #54
    Feb 2004
    NYC
    Leslie,
    I looked at your engine bay and wonder to my self. Wow, how did you manage to keep it so spotless. You have to tell me. I'm afraid to open my hood cause it's a mess in there.
  5. #55
    Jan 2002
    Long Island, NY
    I dono, I never even cleaned it yet.
    I do park inside my garage, I know that helps.
    I drive in salty snowy roads too. The engine bay stays clean. Just slighty dusty, I got almost 10k miles on my car. Picked it up in July 2003.
  6. #56
    Feb 2004
    For what it's worth, I'm another STi owner, and with Wi77iam's pictures had the confidence to install my Xenarc in the dash. The results are great, looks factory installed. I will say, though, that the glare and all is a killer. On a bright day (and we have a lot of them in southern California) I can't see a damn thing. Mind you I haven't played around with it much as I'm having some computer trouble. So I might have to tint the windows.
    Quincy
  7. #57
    Jan 2002
    Long Island, NY
    Yeah, I too will tint my windows very light though.
    The great thing about my screen is the ability for it to move around and avoid glare. I didn't think of that till I started using it.
  8. #58
    Mar 2004
    West of Philly
    Hello! Looks like we have some people close to PA here - if anyone with a completed system is willing to drive to PA so that I can check out your system, I would repay you with discount dyno time (I own an AWD dyno), discount ECUTek, etc. We have a two day WRX dyno day coming up as well...
    I have an Empeg in my Durango, and just picked up a WRX, and think I want to go in-car PC this time. I was originally thinking of going headunit + touchscreen, but I see so many people happy with no HU that I might consider it. FM is very important to me...
    Thanks!
    Josh
  9. #59
    Jan 2002
    Long Island, NY
    No matter if you got HU or no HU the FM reception gets poor when you turn on the PC.
    It did it in my Old Prelude, my STi, and my friends Jetta install. - All three have different antenna's. Power/Glass/Roof.
    I think it's EMI.
    Do you carry the Delta Dash program for my STi? I want to interface the OBD2 into the USB port with the USB key.
  10. #60
    Jan 2004
    Quote Originally Posted by quinxy
    Quincy
    Curious to know if this is an older model xenarc or the newer brighter ones? I just ordered a new model 700tsv.... I'm going to have the tints down to about 35% or so. I think the older models are rated at around 200 nits (could be wrong) and the newer ones are close to 300.
    2002 Subaru WRX - Silver
    -FP18G turbo
    -Walbro fuel pump
    -Modified OEM 840 CC Injectors
    -TurboXS: UTEC, turboback, uppipe, intake
    -Blitz FMIC
    -STI cluster
    -17"x7.5" SSR Competitions
    -Tein Flex coilovers
    -NOS 50 shot
    -2004 rear conversion
