I hope someone can give me some info on what to try next to get this thing to work. I have used info from both the starfox and mpro mod and the display is working but there is a constant barrage of horizontal black lines across the screen. The lines are black, i.e. they only show up on lighter colors, if I set the background to black, I do not see white lines on a black background. They are roughly 3/8"-1/2" long and appear randomly all across the screen, almost like snow. I am using starfox's wiring setup but no 5v, have tried using it but doesn't help and the screen works without it. Using mpro's timing information for NTSC (it is a US device). If I adjust the horizontal Sync width and/or front porch values in powerstrip, the black lines go away once I up those values to 72-88. The screen also gets significantly brighter, but there is still some visual artifacting in the upper left corner. Basically the screen is there but there is a greyish band that kind of arcs across that corner. Also as the screen gets brighter the text seems to degrade slightly, becoming slightly more pixellated. So having said all that, any ideas? Many thanks again to starfox and mpro and everyone else who contributed to this mod!
