Page 1 of 3 123 LastLast
Results 1 to 10 of 26
Thread: recognizing Thrustmaster PSOne
    Jan 2004
    Hi PSOne Modders,
    Iīm glad to have my Thrustmaster PSOne Screen connected to my PC with a reasonable picture. Iīve tested all the different modīs, but only MPROīs one has worked (in NTSC-Mode, the Screen is switcheable). Now my next problem is to get it recognized by the graphics card. Iīve tested it with three different cards:
    ATI Radeon 7500
    ATI 9800SE AIW
    Matrox Mystique 220 PCI
    I have connected PINs 4+11 (VGA) to PIN 8 (Thrustmaster), but that didnīt work. Has anybody connected his Thrustmaster Screen to one of the cards above and if yes, how ? ? ?
    Thankīs a lot upfront for your support
    Bonzo
    Jan 2004
    Clarification Please...
    Do you mean recognized as a secondary display? I have the official Sony LCD, and haven't had a problem with the display coming on as a single display with a Matrox Mystique (not sure which model) had problems with clarity on the display though. If secondary card, have you tried putting +5 into the LCD from the video card?
    Quote Originally Posted by bonzo206
    Hi PSOne Modders,
    ATI Radeon 7500
    ATI 9800SE AIW
    Bonzo
    Jan 2004
    If I connect the Thrustmaster to the AIW or 7500 as secondary, I see a picture on the screen, but the configuration of the card (properties/enhanced/view), where I could setup the different connections (VGA, TV, DVI) says, that no monitor is connected and therefore I couldnīt set up a different resolution to the display.
    I hope this describes my problem a little more
    Thankīs again for your help
    Bonzo
    Jan 2004
    Sorry I'm not gonna be much help on this one. I haven't set mine up as a secondary. I've been setting it up as a single display on a Matrox G200 (originally used a Matrox Mystique but I think there was a problem with that card because it worked but there was some kind of horizontal scan freq. problem that made the image not clear). To work with LCD as an only monitor w/o worring about losing the whole shooting match if it went out of sync, I've been viewing the computer it is on throught XP Pro's remote desktop control on my main computer. Regarding the LCD as a secondary I think FoxPro was saying that he had to hook up a regular monitor for the card to detect, and then switch it with the LCD. I've had no problem using the LCD as a primary though. Everything up until powerstrip loads is squirrly looking but I understand there is a BIOS mod I can do on the Matrox G200 that will put it in a permanant 15Hz setup, so I should be able to see MB BIOS settings etc with the LCD. Best of luck to you!
    Bonzo
    Oct 2004
    Cool
    Did you get it to work with the ATI Radeon 9800??
    I have same problem. but i only have one card so i cant realy test it. im stil unsure if it is connectet the right way. So im planning on building the conposite converter and then use it in that way.
    or buy me a sony display
    but it would be vary nice if anyone could give some support on the thrustmaster display.
    Raw Wave
    Jun 2003
    Before you build the composite converter download powerstip first and see if the card supports it.
    My Radeon on the compaq evo n1000v support composite so I guess your one should as well.
    Oct 2004
    Quote Originally Posted by Ricky327
    It has s-video out. so it should work??
    my card is a Shappire radeon 9800 pro 128mb ram with the old r350 chip
    And then I was mod. Tidder's Avatar
    Sep 2003
    New Mexico, USA
    I use an Nvidia Geforce4 MX440 and mine works just fine.
    I am confused by your post a little though...
    You say you're happy that you have it working with the PC, then you say you can't get the graphics card to recognize it. What exactly is going on here?
    You should install Powerstrip and try it. I think what you're saying is your PC doesn't see your LCD connected to your secondary vid, so you can't change the resolution. Is that correct? If so, what were you using to change the resolution/timings anyway?
    Powerstrip is probably the answer.
    Tidder
    Try RevFE
    Sep 2003
    New Mexico, USA
    As far as your problem wrath, I think I've seen something about video card not detecting a display plugged in, so it doesn't send video signal. Do a search on it...
    I'll search a little too.
    Tidder
    Try RevFE
    Oct 2004
    I have tested my card and i can run 2 monitors on one card but cant get the freeking display to work at all. If it works at all i dont know.
    Ill redo my wires later this evning and se if it works. else im buying the parts fr the convertor tomorrow and see if that helps me.
    btw. what settings should i run in powerstrip if i run the display from tv-out?
  1. Thrustmaster PSOne Screen - help !!!
    By bonzo206 in forum LCD/Display
    Last Post: 01-11-2004, 02:10 PM
  2. PSOne Screen and Video
    By MatrixPC in forum LCD/Display
    Last Post: 12-24-2003, 11:24 AM
  3. Thrustmaster PSOne LCD Screen Removing Backlight
    By Daninino in forum LCD/Display
    Last Post: 08-06-2003, 04:37 AM
  4. FOR Sale= Black PSONE LCD
    By jsm49ers in forum Classified Archive
    Last Post: 01-05-2003, 02:04 AM
  5. PSone LCD help needed
    By jsm49ers in forum LCD/Display
    Last Post: 11-10-2002, 10:20 PM
