Page 5 of 5 FirstFirst 12345
Results 41 to 48 of 48
Thread: Using an OEM vehicle navigation screen
  1. #41
    Constant Bitrate Needstorage's Avatar
    May 2004
    Belgium
    Quote Originally Posted by Aksor
    Hey guys check out some of the SONY PS1 LCD to VGA mods.
    The Sony 5" LCD has the same RGBS interface and runs on 15kHz.
    you can use an ATI or Matrox Video card and power strip an select Arcade mode from the custom resolution this will give you the 15kHz required.
    BTW flip flops will not work cause the RGB color data is still sent out at 31kHz and your vertical sync will be out of sync
    Laz
    Well, I've tried using PStrip, but i didn't get closer to seeing my desktop twice on the screen.
    Needstorage
    Who the hell is general failure?!?
    And what the f@#k is he doing reading my drive C:\?
  2. #42
    Jul 2004
    Lisbon
    Quote Originally Posted by Needstorage
    Wel, maybe you can answer the next question then: When you're driving the car, the in dash OEM screen just switches back to whatever it was in before it was playing the video-signal. (For safety-reasons) Is there a way around this problem?
    Can you exlpain better your question ?
    Yes .... it's automatic when you switches back, for instance it goes to gps or cd player or even radio ...
    to have this possibility you must disconect the "gala" system ... it get the velocity and cut of the image when you are driving ....
  3. #43
    May 2004
    Belgium
    Quote Originally Posted by jmaleixo
    I don't think I need to explain furthermore, because you just answered it. I had a clue it had something to do with the SCALA signal. I just wondered. thanks for the reply!
    Needstorage
  4. #44
    Jan 2004
    Chicago, IL USA
    Needs,
    Nice job finding the converter! Unfortunately, I don't think it'll work with my system. The connectors are way different, and I am thinking that it wouldn't work anyway.
    The thing is, the readings I am getting on the OEM video signal just don't match up with a digital signal. I could be wrong, but I really don't think it seems correct.
    In any case, good luck with your interfaces guys! I am still working on mine.
  5. #45
    May 2004
    Belgium
    Quote Originally Posted by Mr Castulucci
    Needs,
    Hey, don't think that another shape of connector means your stuff is incompatible, because I'm pretty confident in this thing. Although I'm not gonna get it (for the moment) because I already have my CarTFT 7" TS for a month and I'm working on my software and my case.
    I'll post a picture in a couple of days showing you that having an OEM-connector does not mean that you can 't use it. (In my car I have a 12-pin mini-din connector at the back of my OEM GPS/audio/screen-system. This is custom, a 10 pin mini-din connector is pretty hard to find. (Although they have it in the store that also sells the converter in previous post) I'm not gonna buy it there because I already have created my own 'custom' connector for it. It's very cheap and it works fine.
    Needstorage
  6. #46
    Jan 2004
    Chicago, IL USA
    Needs,
    I don't doubt that it will conceptually work with my application, but the thing is, I don't think that my screen is looking for a digital RGB signal. I'm almost positive that the signal is analog, and that's why I am having so much trouble with it. I could be wrong though...
    I just e-mailed Denso Corp in Australia...hopefully they can help me out or at least point me in the right direction (Denso is the manufacturer of my OEM navigation computer).
    -Frank
  7. #47
    Newbie Vijindr's Avatar
    Jul 2004
    Hi, I haven't read this too closely so I might be reposting something that was already suggested... but there's quite a few aftermarket devices out there that let you tap into the nav system and output different sources into the nav screen.. nav-tv is one of them.. I saw a fairly good one a while back for about $500 US but I forget what it was called... Keep in mind though, I never saw anything about factory touchsreens here, so you might have to check (nav-tv in particular seems to specialize in more high-end vehicles)
    hope that helps.
  8. #48
    Variable Bitrate Fox_Mulder's Avatar
    Melbourne, Australia The Truth Is Out There
    On the Touchscreen integration i googled the terms and I got these links:
    This guy has integrated an mp3-cd player into his Toyota Prius Touchscreen:
    http://www.angelfire.com/electronic2/mp3hack/
    More on the controls for the above mod:
    http://mywebpages.comcast.net/bumpelo/user.html
    [edit]
    Basically, instead of out-putting the Image to the screen, you can use the OEM CD Changer image, and have the computer output CD-TEXT to the Nav computer. Then analyse the signals the nav system outputs when you press each button (on the touchscreen), and tie those outputs to the computer's parallel port and have the computer react appropriately to each of these signals.
    [/edit]
    Hope this helps!
    Fox Mulder
    2004 Toyota MR2
    Modified Intel Xeon E5450 3Ghz Quad Core 2GB RAM 160GB SSD M4ATX Xenarc 700TSV TS Toslink Audio BU353 DiNovo Mini Car2PC ODBII Bluetooth HF 16x2 Character LCD
  1. Replies: 21
    Last Post: 08-27-2006, 02:26 AM
  2. Gamecube screen
    By junior in forum LCD/Display
    Last Post: 11-24-2003, 07:38 AM
  3. lillyput--all hype?----long review
    By liquid_smoke in forum LCD/Display
    Last Post: 11-21-2003, 11:44 AM
  4. BMW pre-installed system - TFT ?
    By tsingsu in forum LCD/Display
    Last Post: 08-05-2002, 03:16 AM
  5. Replies: 13
    Last Post: 07-02-2002, 11:54 AM
