Results 1 to 10 of 10
Thread: Touchscreen not working for my new Lilliput!
    Jan 2004
    Stockton, CA
    I just gotten my lilliput two days ago, and finally hooked it up to test out the features. I plugged the usb plug into my computer and windows xp prompted me to install the drivers for the new usb device that was found so I installed the software/drivers for the touchscreen from the mini disc that came with it. After the software was installed a good reboot was need and after I rebooted I ran the touchscreen software. It found the device and drivers, so I tried to do the 4 point calabration. My touchscreen overlay was not responsive when I touched it! Did I recieve a defected lcd or did I not install the drivers/software correctly? Please help!
    Oct 2003
    Run system restore to before you installed this... then unplug your usb cable. Hook up a normal mouse and go back into windows. run the install from the mini disc and then plug the usb cable in again. Let it install.... then if it needs to be directed anywhere try directing it to the X:\feel screen\win2000_xp (X: is whatever your optical drive is)
    If that doesn't work.... I'm out of suggestions!!!
    Good luck
    New CarPC on the way again I think. I miss my old one!!!
    May 2003
    I have exactly the same problem, and mine is still not working.
    I have tried it on two different CP but without sucess.
    I'm thinking of buying a new touchscreen, its to expencive to send the screen back to US for me . But i havent found and company that sells 7" touchscreens here in europe
    //Peter
    Quote Originally Posted by robutek
    Oct 2003
    Have you tried anything I have mentioned? Its probably a driver issue, at least when I had the exact same problem it was!!! Also you may want to crack open the lilliput and ensure that the touchscreen is plugged in!!!
    Raw Wave Laidback's Avatar
    Oct 2003
    Madrid
    Quote Originally Posted by R3l0ad
    As he said....run INSTALL.EXE from the CD.
    Jan 2004
    I've got one. It doesn't seem to work unless you use your nail of the stylus. If you get it working with your finger give me a shout because I haven't installed mine yet.
    Jan 2004
    Zürich
    Hi. You can get super quality 7" Touchscreen Monitors from a company called www.car-comp.com. They are better than the Lilliput but more expensive. They are based in Switzerland so the shipping shouldn´t be too bad for Europe.
    Jun 2002
    Malaysia
    I had this problem on my primary PC. I think you will have to system restore back to the point before you installed the driver.
    I went to another of my WinXP pc and installed the WIN98 touchscreen drivers and software. It then worked perfectly.
    I tried removing and everything on my primary winXP pc (i dont have system restore enabled on my primary) and installing the drivers from scratch again, but it wont work.
    But hey, if you wanna sell your faulty(?) lilliput, let me know. I may take it off your hands if its cheap. I live in South East Asia.
    Dec 2003
    Try www.cartft.com for touchscreens, where i got mine, 2 days del.
    Newbie stevepud's Avatar
    Jan 2004
    UK
    Just a thought, I'm sure you have probably already covered this yourself... but.....
    When I connected my Lilly Touch screen, it disabled the onboard mouse (i connected to a laptop, and lost the nipple mouse)
    I had to go into the BIOS and choose SIMULTANEOUS with regard to multiple mice.
    Maybe this is your problem?
    Maybe the PC is only going to see one mouse (you know the actual touchscreen function is just seen as a USB/PS2 mousedont you?) and the one it is seeing is your existing one
    Anyway, try setting the mouse to Simultaneous and see how you go
    Hope that helps.
    Steve
    - A complete Carputer novice!! -
  1. exact outer size of 7" lilliput touchscreen?
    By cotwild in forum LCD/Display
    Last Post: 01-08-2004, 01:43 AM
  2. Replies: 15
    Last Post: 01-05-2004, 04:40 PM
  3. speaker next to lilliput touchscreen. clever?
    By sham in forum LCD/Display
    Last Post: 11-02-2003, 05:47 PM
  4. touchscreen not working
    By Birrman54 in forum LCD/Display
    Last Post: 09-15-2002, 12:09 PM
  5. Yea! Got my touchscreen / lcd working
    By Arby in forum LCD/Display
    Last Post: 03-06-2002, 06:08 PM
